Endpoint Audio
Butikk Lampizator Amber AMP/DAC
Denne annonsen er utgått.
Integrert forsterker
Selges
Tilstand
Ny
Utløpsdato
Fylke/land
Vestfold
Pris
Kr 135.000
Annonse beskrivelse
Annonse nummer: 251188
Integrert forsterker med innebygget DAC + analoge inputs.
Den perfekte alt i ett boksen for deg som er opptatt av god lyd. 2x10W er mer enn nok med riktige høyttalere. Og som med alt fra lampizator så er det ikke tatt snarveier. Her er lydkvaliteten viktigst!
Dette er hva Lampizator himself sier:
-Amber amp - is the product I am most proud of. My original idea of interweaving the DAC circuit directly into the power stage of a great push pull amp resulted in a unique product.
What makes it special, is that a relatively simple DAC and relatively modest amp, as a sum, give 1+1=4. Not even 3. The Amber Amp is much greater than sum of its parts, and sounds 2 classes better than our Amber DAC connected externally to a Push Pull EL84 Amp. The technical synergy between the DAC and the push pull amp is just stunning. The Amp can do away with the single biggest evil of amps - the PHASE SPLITTER.
Instead in this simple and elegant design the chip itself drives each push pull triode directly. We run EL84 pentodes in tetrode mode, with ultralinear taps. This amp has to be heard to be believed.
Main features: 4 and 8 Ohm taps, USB and SPDIF and TOSLINK inputs, per request - three headphone outputs - because it makes a phenomenal headphone amp. For headphones we use one big Jack,One small jack, XLR 3 pin balanced and 4 pin balanced XLR sockets.
DAC section does DSD512 as well as 384K PCM. Volume control is by means of a microprocessor switched 64 step relay board - step resistor ladder of highest obtainable quality.
MAIN PARAMETERS:
10 Watts stereo pure tube amplifier, switchable to headphone mode,
line level analog inputs - balanced and SE. Digitalk inputs USB, SPDIF and TOSLINK. Remote control. Power consumption 200 Watts. 115/230/240V operation. EL84 tube swith ecc99 drivers. Polish made high quality Ogonowski transformers for power and output as well. Choke filtering PSU. Weight 30 kg. Shipping weight 40 kg. Chassis dimensions H/W/D = 13 x 43 x 52 [cm]
Originalemballasje
Ja
Orig. kvittering
Ja
Forsendelse
Kan sendes
Endpoint Audio
Torget karakterer
Vurderinger (39)
Andre annonser av Endpoint Audio
