Real time staging
The circuitry inside the award-winning Essential Phono is closely based on that of the class leading Agena Reference Series Phono stage. its performance is simply astonishing at this price point; it was designed not just to compete favourably with its competitors, but to completely overshadow them, even those at 3 or 4 times the price.
The subtle musical information from the phono cartridge is handled with such delicacy that many listeners will never have experienced the levels of clarity, of dynamic accuracy, the soundstage dimensionality, and authenticity of tone and timbre that is produced ? at any price.
The Essential Phonostage is switchable for use with both moving coil and moving magnet cartridges and includes a switchable low frequency filter. The low frequency filter only operates below 20 Hz to stop the by-product of warped records and turntable motor or bearing noise.
Acclaim
"Recommended"- Art Dudley, Stereophile
Declaring it "Best Buy", the-ear.net said
"If you want to add engagement and hear more of the inner detail from the groove the Essential is a class act at a competitive price."
the-ear.net Best Buy badge
Awarding it 5 Stars, the Essentials Phono Stage was Hi-Fi Choice Group winner, Janurary 2013.
"...the Essentials put in a consistently strong performance with all types of music..."
"...the Leema has a sense of timing and control that makes it easy to listen to..."
"The low noise floor and impressive microdynamics were also remarked upon..."
"Throw in the solid build the ability to handle moving coil cartridges, and you have a most worthy group winner."
What Hi-Fi? Sound & Vision: Best Phono Stage, 2011
Features/Specification
Moving magnet gain: 36 dB
Moving coil gain: 62 dB
Frequency Response: 20 Hz to 20 kHz (+/- 0.5 dB ref > RIAA curve)
Distortion: Less than 0.02% (@ 1 kHz)
Moet Audio holder til like utenfor Stavanger sentrum, og er pr.idaq Stavangers ENESTE Hifibutikk ,
I Lagårdsveien 77.
Selskapet er en importør og distributør kvalitets Hi-Fi, og fører blant annet kjente merker som Xindak, Leema Audio, Diptygue Audio, Black Rhodium, Revival Audio, Silent Pound, Audio Hungary etc
Vi har et bredt sortiment av produkter, slik at "alle" kan finne noe de liker, uavhengig prisklasse. Alle våre produkter er anerkjente for ytelse og kvalitet, noe som bekreftes i tester og utmerkelser fra nasjonal og internasjonal fagpresse.
Du finner våre annonser på Finn.no og kan følge oss på Facebook.
Vi har demo produkter tilgjengelig som kan lånes hjem for test.
Ta kontakt for et godt tilbud og en uforpliktende HiFi prat!
Vi kan tilby god service og oppfølging, kvalitet i leveransene, samt gode priser.
Hos oss har kunden en garanti for at evnt reklamasjoner blir behandlet på en effektiv måte.
Nye Åpningstider Moet Audio fra 18 mai :
Mandag : Kun avtalte private visninger, ta kontakt på mail.
Tirsdag : 1100-1700.
Onsdag : Kun avtalte private visninger, ta kontakt på mail.
Torsdag : 1100-1700.
Fredag : Kun avtalte private visninger, ta kontakt på mail.
Lørdag : 1200-1600 Åpent partallsuker,Dvs annen hver lørdag
Ønsker du privat visning ta kontakt på : post@moetaudio.com eller på telefon 96919519
Residual noise (MM): Better than -86 dBA (input short circuit)
Residual noise (MC) | Better than -75 dBA input short circuit
Load characteristics (MM): 47 k?, 100 pF
Load characteristics (MC): 90 ?, 1 nF
Input sensitivity (MM): 4 mV RMS for 250 mV RMS output
Input sensitivity (MC): 180 µV RMS for 250 mV RMS output
Headroom: Greater than +26 dB @ 1 kHz
High pass filter: -3 dB @ 20 Hz
Dimensions (wdh): 113*102*60mm
Carton: 320*160*110mm
Mass: 11Kg
Acclaim
I Lagårdsveien 77.
Mass: 11Kg
