Lumin A1 Nettverksspiller til salgs. Jeg har hatt denne i 9 måneder og er ekstremt fornøyd med den.
Dette er vel den mest omtalte nettverksspilleren som har fått best ialt.
Den er 100% strøken, kommer i originalboksen og låter vanvittig bra.
Nyprisen er 59.000,-
tom@endpointaudio.no
47832922
A1 Specification
47832922
A1 Specification
- DSD Support:
- DSD64 2.8MHz, 1-bit
- HDMI Output:
- PCM 44.1kHz?192kHz, 16?24-bit
- DSD 2.8MHz, 1-bit
- Analog Output Stage:
- Wolfson WM8741 DAC chips, 1 chip per channel
- Fully balanced layout with high-quality components
- Output connectors coupled with dual LUNDAHL LL7401 output transformers
- Power Supply:
- External dual-toroidal
- Available in 240V and 110V versions
- Physical:
- Lumin (solid aluminium chassis):
- 350mm (W), 345mm (D), 60mm (H), 8kg
- Dual-toroidal PSU:
- 100mm (W), 295mm (D), 55mm (H), 2kg
- Streaming Protocol:
- UPnP AV protocol with audio streaming extension
- Gapless Playback
- On-Device Playlist
- Supported Audio File Formats:
- DSD Lossless:
- DSF (DSD), DIFF (DSD), DoP (DSD)
- PCM Lossless:
- FLAC, Apple Lossless (ALAC), WAV, AIFF
- Compressed (lossy) Audio:
- MP3, AAC (in M4A container)
- DSD Lossless:
- Supported Audio Sample Rates, Bit Depths, Number of Channels:
- PCM, 44.1kHz - 384kHz, 16 - 32bit, Stereo
- DSD, 2.8MHz, 1bit, Stereo (5.6MHz on LUMIN S1)
- Upsampling rates & bit depths:
- DSD upsampling option for all files up to 96kHz
- Supported Control Devices:
- All models of Apple iPad (v2 or later). iOS 5.0 or later required. Full Retina Display support.
- App Features:
- High-resolution artwork. Artwork caching. AirPlay compatibility. Multiple-tag handling. ?Composer? tag support. Find & Filter. Tag browsing.
- Input:
- Ethernet Network 100Base-T
- USB storage, flash drive, USB hard disk (Single-partition FAT32, NTFS and EXT2/3 only)
- Outputs:
- Analog Audio:
- XLR balanced, 4Vrms, pin 2 Hot
- RCA unbalanced, 2Vrms
- Digital Audio:
- BNC SPDIF:
- PCM 44.1kHz-192kHz, 16-24bit
- DSD (DoP, DSD over PCM) 2.8MHz, 1bit
- DSD (Native or DoP) 2.8MHz, 1bit
- BNC SPDIF:
- Analog Audio:
