Innbyttemodell - Fra Februar i år - som ny.
Lumin T2 er en ekte High End Streamer med innebygget DAC og her får du alt i en boks! Dette har blitt en seriøs storselger og tilbakemeldingene er overveldende. Dette er en av de beste digitale kildene jeg har hørt uansett prisklasse.
Info fra produsenten:
The performance
sweetspot
All-new chassis construction combines with X1 technology to provide the perfect balance.
Why LUMIN T2
LUMIN T2 heralds the first redesign of the classic A1/T1 main boards and chassis. This new approach combines solid cnc panel construction with X1 technology to hit the performance sweet spot.
All-new chassis construction featuring thick cnc panels and an internal power supply
New generation processor provides DSD512 and 384kHz playback
Dual ES9028PRO SABRE DACS
USB digital audio output
Precision 32-bit internal digital volume
Discreet clock system for precision timing
Low-noise switching power supply with dual stage regulator
PCM & DSD upsampling
MQA full decoding
Roon Ready, Spotify Connect, MQA, TIDAL, Qobuz, Airplay and TuneIn
All the usual LUMIN refinements
From MQA to DSD, FLAC to WAV, LUMIN can play all the high-resolution formats you could ever want
Native support for TIDAL, Qobuz, Spotify and AirPlay, giving you access to tens of millions of songs
The unique and intuitive LUMIN App described as "the most convenient interface in existence" by Tinman
LUMIN programme of continuous development that has seen Roon, MQA, and Spotify support added in 2017 alone.
T2 Specification
DSD Support:
Up to DSD512 22.6MHz, 1-bit
PCM Support:
Up to 384kHz, 16?32-bit, Stereo
Analog Output Stage:
Dual ESS SABRE32 ES9028Pro DAC chips
Fully balanced layout with high-quality components
Completely redesigned analogue buffer includes audiograde output capacitor and ultra-low-noise and high dynamic range
Upsampling rates & bit depths:
DSD128 upsampling option for all files
PCM 384kHz upsampling option for all files
Digital Output Stage:
USB:
Native DSD512 support
PCM 44.1?384kHz, 16?32-bit, Stereo
BNC SPDIF:
PCM 44.1kHz?192kHz, 16?24-bit
DSD (DoP, DSD over PCM) 2.8MHz, 1-bit
Power Supply:
Internal 100?240V AC auto-ranging
Low-noise
Shielded power supply compartment for reduced interference with delicate electronics
Physical:
Finish:
Black anodised brushed aluminium
Raw brushed aluminium
Lumin (solid aluminium chassis):
350mm (W), 345mm (D), 60mm (H), 6kg
Specification for all LUMIN music streamers
Streaming Protocol:
UPnP AV protocol with audio streaming extension (OpenHome)
Roon Ready
Spotify Connect
Apple AirPlay
Gapless Playback
On-Device Playlist
App Features:
Native support for TIDAL, MQA, Qobuz and TuneIn Radio.
Tidal MQA icons to identify high-res music
Qobuz high-res icons to identify high-res music
Volume control
High-resolution artwork
Artwork caching
Search
Multiple tag handling
Composer tag support
Album-grouping in playlist
Automatic internet links to artists/album/songs
Saving and restoring of playlists (including Tidal and Quobuz)
Supported Audio File Formats:
DSD Lossless: DSF (DSD), DIFF (DSD), DoP (DSD)
PCM Lossless: FLAC, Apple Lossless (ALAC), WAV, AIFF
Compressed (lossy) Audio: MP3, AAC (in M4A container)
MQA
Input:
Ethernet RJ45 network 1000Base-T
USB storage, flash drive, USB hard disk (Single-partition FAT32, NTFS and EXT2/3 only)
Analogue Audio Outputs:
XLR balanced, 6Vrms, pin 2 Hot
RCA unbalanced, 3Vrms
Supported Control Devices:
All models of Apple iPad (v2 or later). iOS 8.0 or later required. Full Retina Display support.
Android devices. Android 4.0 (Ice Cream Sandwich) or later required
Other:
Programme of Continuous Development ? Firmware-upgradable for further features and enhancements
The performance
sweetspot
Why LUMIN T2
MQA full decoding
T2 Specification
DSD Support:
PCM Support:
USB:
BNC SPDIF:
Power Supply:
Low-noise
Physical:
Finish:
Streaming Protocol:
Roon Ready
Spotify Connect
Apple AirPlay
Gapless Playback
On-Device Playlist
App Features:
Volume control
Artwork caching
Search
MQA
Input:
Other:
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
