Innbyttemodell U1 mini - sort,
Denne er fra i år og selges for kunde.
Dette er en av de mest anvendelige streamerne på markedet - og har du allerede er DAC, så er dette streameren for deg.
Lumin lanserte i 2018 en rimeligere utgave av toppmodellen U1 High End streamer uten DAC.
Her får du brukervennlighet og superlyd i en liten og kompakt kasse.
Her er hva en fersk Lumin eier sa etter kun kort tid:
Må si jeg er forbauset over hvordan skarphet er vekk som dugg for solen, og mellombass spiller høyere, og med mye mindre forvrenging. En sånn streamer burde jo være obligatorisk i dyre anlegg?!
Soundrebels har testet denne og her er konklusjonen til Marcin Olszewski:
- the U1 Mini is an almost ideal solution for all DAC users from a very broad price spectrum, as the tested device is fairing greatly surrounded by units of its own level, as well as many much more expensive ones, if you remember about using appropriate cabling, allowing it to show its full potential. So if you own a DAC, which fits your taste ideally, and an appropriately refined system, and would not like to lose anything from its class, obviously, while moving to the sea of files and streaming, I would warmly recommend to start your search from this modest transport.
Marcin Olszewski
Why LUMIN U1 MINI
Following the huge success of LUMIN D2, we decided to investigate the possibility of making the LUMIN transport technology similarly accessible.
The result is a huge specification in a compact package.
Capable of upsampling and downsampling all the way from 44.1kHz to DSD128 and supporting playback of DSD256, LUMIN U1 MINI matches the U1 in almost every area - except price.
Transport-only unit combines the best of LUMIN U1 and LUMIN D2
Identical processor supports DSD256 and 384khz playback
Quad native clock system for precision timing
Low noise shielded switching power supply
5 types of digital audio output including USB
MQA Decoding
Resamping to every supported format up to DSD128
Supports DoP (DSD over PCM) for Optical, Coaxial RCA, Coaxial BNC & AES/EUB SPDIF
All the usual LUMIN refinements
From MQA to DSD, FLAC to WAV, LUMIN can play all the high-resolution formats you could ever want
Native support for TIDAL, Qobuz, Spotify and AirPlay, giving you access to tens of millions of songs
The unique and intuitive LUMIN App described as "the most convenient interface in existence" by Tinman
LUMIN programme of continuous development that has seen Roon, MQA, and Spotify support added in 2017 alone.
U1 MINI Specification
DSD Support:
Up to DSD256 11.2MHz, 1-bit
PCM Support:
Up to 384kHz, 16?32-bit, Stereo
Digital Output Stage:
USB: DSD256, 11.2MHz, 1-bit, Stereo
PCM 44.1?384kHz, 16?24-bit, Stereo
Optical, Coaxial RCA, Coaxial BNC & AES/EBU:
DSD (DoP, DSD over PCM) 2.8MHz, 1-bit
PCM 44.1kHz?192kHz, 16?24-bit
Power Supply:
Internal shielded 100?240V AC auto-ranging
Raw brushed aluminium or black anodised brushed aluminium
U1 Mini unit:
300mm (W), 244mm (D), 60mm (H), 3kg
Packaging:
470mm (W), 340mm (D), 170mm (H), 4.5kg
Tom Egil
Marcin Olszewski
Why LUMIN U1 MINI
MQA Decoding
DSD Support:
PCM Support:
Power Supply:
U1 Mini unit:
Packaging:
Tom Egil
- Originalemballasje
- Ja
