Marantz NA-11S1 flaggskip nettverkspiller/DAC selges. Fantastisk lyd, som en god platespiller, lite brukt og helt som ny. Har original eske, fjernkontroll, oppsett CD og bruksanvisning. Koster ny 40 000.- Selges billig 18 000.- pga overgang til enklere oppsett.
Se gjerne tester på nett bla i Stereophile som har hatt den på recommended components liste siden den kom ut ;
2014, 2015, 2016 Recommended Components Disc Players, Transports & Media Players
Launched to celebrate Marantz's 60th anniversary, the NA-11S1 is a remote-controlled, network-connected media player and D/A processor with two user-selectable digital filters and direct access to SiriusXM, Pandora, Spotify (separate subscription required), and Internet radio. A front-panel type-A USB connector can be used both to connect an iPod and to play up to 24-bit/96kHz files from a USB memory stick, while a rear-panel USB2.0B port allows the NA-11S1 to decode high-resolution PCM and DSD audio streamed from a PC. Though it can play WMA, MP3, ALAC, WAV, and FLAC files, the NA-11S1 is incompatible with AIFF files. The player also has a front-panel headphone jack, coaxial and optical S/PDIF outputs (on XLRs), and balanced and unbalanced analog outputs (on RCAs). The Marantz held its own against the 12-times-more-expensive MSB Diamond DAC IV, with a sound that was smooth, warm, and natural, only slightly sacrificing leading-edge definition, dynamics, and sense of pace, said JA. "This is a first-rate D/A converter that offers sound quality competitive with the best at a relatively affordable price," he summed up. (Vol.36 No.10 WWW)
Read more at http://www.stereophile.com/content/...-transports-media-players#2WVtICuEKjW7oYth.99
