E80CC er et SQ (Special Quallity) rør fra Phillips/Mullard. Phillips kjøpte Mullard på 1920-tallet etter det jeg vet, så vi kan vel anta at de samarbeidet på et vis. Jeg har iallefall funnet Philips og Mullard produksjonskoder litt om hverandre uavhengig av hvilket brand røra er merket med. I mange tilfeller kan E80CC erstatte ECC82. Se sitat nedenfor
"E80CC / 6085:This unusual European tube is basically an industrial type 6085. However, it's specs are similar enough to a 12AU7 that audiophiles are grabbing them up while the prices are still reasonable. The heater life is rated at 10,000 hours, and some have gold pins. The larger box plate structure gives this tube low microphonics and silky smooth sonics.
Some of the Philips Holland versions had the rare pinched waist, where the glass dips inward and actually molds around the top mica plate, giving the plates extra support and virtually eliminating microphonics. There is also a version made at the Amperex factory in Hicksville, NY, which is often priced lower but looks the same and sounds very similar to the Holland version. Since this tube has a much higher Gm and Mu factor than a 12AU7, the gain is going to be greater and this tube will give a more forward presentation.
Awesome in phase splitter applications. If in doubt, check with your amp or preamp manufacturer to see if this tube will work OK in your application. This tube is also about twice as tall as a 12AU7, so installation space in your chassis is a consideration as well. These are out of production, rare, and getting very hard to find. The European types usually command the top prices, but USA types exist as the 6085 and should be a bit lower in cost, but they are also rare and climbing in price. Many USA tubes were actually made by the European factories, so watch for the 6085 USA brands!"
Prisen er 800kr per stykk, noe som er billigere enn de beste ECC82-røra.
Jeg har målinger på alle rør jeg selger, noe annet er vel direkte uansvarlig selv på nye og ubrukte rør. Jeg har vært borti en hel del mer eller mindre deffekte rør som jeg selv har pakket nye ut av boksen. Det at et rør settes inn i en forsterker og lyser og virker i betydningen gir lyd er slettes ikke noen garanti heller for at røret er i bra stand, lyd er lyd, bare god lyd er god lyd!
Jeg målte nettopp gjennom 6 rør i en 100.00 kroners preamp som var kjøpt av importør med kun 1 år gamle rør, fire av de seks røra målte mellom 30 og 35 % av spec, de to siste røra målte 17 % og 100 %! Ikke rart det låt litt dafft og med dårlig kanalbalanse i et ellers svært ambisiøst oppsett.
Kan hentes hos meg i Oslo, og jeg sender gjerne i posten, for kjøpers regning og risiko.
Alle som henvender seg med navn, adresse og telefonnr får svar.
Det er fint om de som har mange spørsmål ringer.
Jørn B. Hauge, Oslo, 99024911
joernbh@gmail.com
joernbh@gmail.com
