jbh
Mullard E80CC (variant av ECC 82)
Løse rør
Selges
Tilstand
Ny
Utløpsdato
Fylke/land
Pris
Kr 600
Annonse beskrivelse
Annonse nummer: 228092
E80CC er et SQ (Special Quallity) rør fra Phillips/Mullard. Phillips kjøpte Mullard på 1920-tallet etter det jeg vet, så vi kan vel anta at de samarbeidet på et vis. Jeg har iallefall funnet Philips og Mullard produksjonskoder litt om hverandre uavhengig av hvilket brand røra er merket med. I mange tilfeller kan E80CC erstatte ECC82.
Se sitat nedenfor:
"E80CC / 6085:This unusual European tube is basically an industrial type 6085. However, it's specs are similar enough to a 12AU7 that audiophiles are grabbing them up while the prices are still reasonable. The heater life is rated at 10,000 hours, and some have gold pins. The larger box plate structure gives this tube low microphonics and silky smooth sonics. Some of the Philips Holland versions had the rare pinched waist, where the glass dips inward and actually molds around the top mica plate, giving the plates extra support and virtually eliminating microphonics. There is also a version made at the Amperex factory in Hicksville, NY, which is often priced lower but looks the same and sounds very similar to the Holland version. Since this tube has a much higher Gm and Mu factor than a 12AU7, the gain is going to be greater and this tube will give a more forward presentation. Awesome in phase splitter applications. If in doubt, check with your amp or preamp manufacturer to see if this tube will work OK in your application. This tube is also about twice as tall as a 12AU7, so installation space in your chassis is a consideration as well. These are out of production, rare, and getting very hard to find. The European types usually command the top prices, but USA types exist as the 6085 and should be a bit lower in cost, but they are also rare and climbing in price. Many USA tubes were actually made by the European factories, so watch for the 6085 USA brands!"
Prisen er 600kr per stykk, noe som er mye billigere enn de beste ECC82-røra.
Kan hentes hos meg i Oslo, men jeg sender gjerne i posten for kjøpers regning og risiko mot forskudd til konto eller ved Vipps
Alle som henvender seg med navn, adresse og telefonnr. får svar.
Det er fint om de som har mange spørsmål ringer.
Jørn B. Hauge, Oslo, 99024911
joernbh@gmail.com
jbh
Torget karakterer
Vurderinger (11)
Andre annonser av jbh
  • ECC85-rør selges
    Selges av: jbh
    Ta kontakt
  • Schick tonearmer
    Selges av: jbh
    Ta kontakt
