Selges eller Kan byttes i noe- dac/sonos eller et eller annet
Multicell- 8 celler.
Dette er "diy" mdf horn kjøpt av meg på ebay av en kar som lager og selger disse i et visst volum.
disse er malt i lyse gul/hvit - ser fine ut, men finischen kunne vært bedre.
kan hentes eller sendes, det er festemerker på turen etter drivere.
dette er hva selger skriver om produktet på ebay
1 Pair Of 8 Cell Multicellular Horns
For use with 1" ,1.5 or 2" Throat Compression Drivers
Each Horn approx size 600mm x 400mm x 550mm Deep
with a Disspertion of Degrees 70 x 35 Degrees
The Voids in-between the the cells have been filled with polyester foam to reduce resonance
Each Unit Is An Arrey Of 8 Cells
They Have Got Removable Throats so
you can choose either 1" or 2" throats
depending on your drivers
Started making these about five years ago after searching
for a pair of vitavox or Altec Units which seemed unattainable at the right price
After viewing through the forums I found a few links to people making these units out of wood
But again very high prices, being a cabinet maker I decided to make them myself
The cell units are pure exponential with flare frequency of around 300Htz
The units are made out of 3mm medium density fibreboard which is ideal as it
offers the advantage among other woods of a low resonance and is almost
sonically dead (does not ring ). It has a density of 0.4595. and fairly light weight
for ease of transportation
All are made with detachable throats for upgrading of drivers
They are for sale in unfinished mdf so you can choose your own finish either painted
or stained to whatever colour you like
They are for sale with 2" throats
