Atlerovik
Nordost QRT QX2 strømrens Solgt
Strømfiltere
Selges
Tilstand
Brukt
Utløpsdato
Fylke/land
Pris
Kr 6.000
Annonse beskrivelse
Annonse nummer: 232559
Selger en Nordost QRT QX2 strømrens. Noen bruksmerker, men ellers i pen stand. Nypris på denne er ca 20 000,-
Kan selges sammen med tilhørende Nordost QB8 strømfordeler.
Beskrivelse fra Nordost:
QX2 units are power purifiers that are affective without compromising the peak current capabilities of your power supply or the integrity of your grounding. Each QX unit contains QRT field generators that alleviate the impact of poor quality AC power on your sensitive electronics, limiting RFI and timing errors. Place your QX unit(s) at the heart of your system and you’ll hear a lower noise floor, greater dynamic range, more fluid musical expression and greater space and ambience. QX units allow you to hear more of your music (and less of your system). Used in conjunction with each other as well as the QBASE-Mark IIs, Qv2s and Qk1s, both the QX2 and Qx4 provide a highly effective answer to the insidious influence of poor AC supplies on musical reproduction. And because of QRT’s modular approach to AC treatment, you can add additional units as you go along – they never become redundant. Once you’ve heard the sense of life and effortless musical flow that comes from having QRT technology in your system, you will want more – which is what makes the modular nature of the QRT products so appealing.
Mer info: https://oslohificenter.no/stereo/stromrens/nordost-qrt-qx2
Kan sendes eller hentes i Oslo.
Originalemballasje
Nei
Orig. kvittering
Nei
Forsendelse
Kan sendes
Atlerovik
Torget karakterer
Vurderinger (17)
Andre annonser av Atlerovik
  • «Ny» Lumin U2
    Selges av: Atlerovik
    Kr 44.000
