Demomodell for salg, med alle options. Dette er en skikkelig god integrert forsterker MED DAC, hodetelefonforsterker OG RIAA. Meget vellydende og driver det meste.
Nyprisen er 42.000,-
SPECIFICATIONS:
Type: Integrated stereo amplifier
Inputs: 4x RCA single-ended, optional phono stage, DAC & headphone amp
Outputs: User configurable for subwoofer, tape etc
Input impedance: 47 kOhms
Sensitivity: 130mV
Speaker outputs: binding posts
Optional headphone amp: selectable sensitivity, high current, 6.3mm jack
Optional DAC: 5 input, 24/192 & DSD
Optional phono stage: MM/MC, variable gain & impedance
Rated output power: 75W into 8 Ohms, 150W into 4 Ohms
Supplied accessories: IR remote control
Dimensions H x W x D: 118 x 214 x 370mm
Weight: 12kg
SPECIFICATIONS:
Sensitivity: 130mV
Weight: 12kg
Norma HS-IPA 1 | The Ear
www.the-ear.net
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
