Endpoint Audio
Butikk Norma IPA 80 - 15% Vårtilbud
Denne annonsen er utgått.
Integrert forsterker
Selges
Tilstand
Ny
Utløpsdato
Fylke/land
Vestfold
Pris
Kr 46.900
Annonse beskrivelse
Annonse nummer: 248461
Norma IPA 80
Dette er etterfølgeren til IPA-70B og har fått en kraftigere strømforskyning som gir 2x80W.
Norma Revo IPA-80
Norma IPA80 integrert forsterker kommer med flere valgmuligheter. I denne kan du velge mellom et MM/MC RIAA kort eller en USB DAC. Norma IPA 80 kommer også i sort mot et tillegg på 3500,-
Tilleggsmuligheter:
MM/MC kort – 7.500,-
USB DAC – 10.900,-
This Norma is an intriguing amplifier; it does so many things so well that you have to wonder how Enrico Rossi has achieved it. The ability to combine so many strengths in what is a relatively compact and attractive amp is very unusual, very few do pace this well and it’s equally rare to hear microdynamics delivered so clearly. It certainly makes you wonder about the bigger IPA-140B, which if like this it can double its output into a halving of load must be a bit of a monster. Feature wise the single input DAC might be a limit for some and at this price level some competitors offer balanced inputs, but the DAC itself is very good and personally I’ve yet to hear real benefits in balanced connections where cable lengths are sensible. If you’re in the market for a new amplifier I suggest you put this near the top of your audition list.
Jason Kennedy HiFi+ https://hifiplus.com/articles/norma-ipa-70b-integrated-amplifier/
Mer info her:
Norma IPA 80
Originalemballasje
Ja
Orig. kvittering
Ja
Forsendelse
Kan sendes
Endpoint Audio
Torget karakterer
Vurderinger (37)
Andre annonser av Endpoint Audio
