The Mentor Reference includes the Heavy Platter Upgrade - a 25mm Graphite HD platter which increases the rotating mass and stability of the system and also improves resonance control. The turntable come with a one-off arm mounting designed by Tom Fletcher to allow any size of arm to be mounted accurately to the deck. The Wave Mechanic generates a clean and stable AC signal, improving the performance of any Nottingham turntable. It illuminates all AC fluctuations in the power supply. This upgraded combination Reference + Wave Mechanic creates an inky black background which allows you to hear more detail from your vinyl. Original prices - Mentor Reference with HD platter - €2400 Arm board - € 450 Wave Mechanic - € 700 “The turntable produces quieter backgrounds than any other turntable I’ve had in my home. Whilst offering soundstages of exceptional depth, width, and overall three-dimensionality— arguably the turntable’s greatest strength.” “It delivers a carefully balanced combination of resolution and detail on the one hand, and natural warmth on the other - so why you hear is real musicality.”
NB: Knappen for å vise hele beskrivelsen har kun en visuell effekt.
- Originalemballasje
- Nei
- Orig. kvittering
- Nei
- Forsendelse
- Kan sendes
