Legger ut min Octave RE320 med Super Black Box.
Nydelig røreffekt som drar de aller fleste høyttalere med glans, også takket være Super Black Boxen.
SBB selges ikke separat.
No nonsense rørforsterker med meget enkelt Bias justering.
Forsterkeren er kjøpt ny i Norge i slutten av 2021. Nypris idag med SBB: 138.000kr
Frakt tilkommer (2 pakker)
The dynamic and tonal stability of an amplifier is strongly dependent upon the stability and capacity of the power supply, therefore the Black Box and Super Black Box were developed as external upgrades to the OCTAVE amplifiers’ power supply storage capacitors by increasing their capacitance by a factor of 4 (Black Box) or 10 (Super Black Box), respectively. This is a tremendous benefit if the speaker is difficult to drive. Loudspeaker efficiency is made less critical, while the amplifier is enabled to handle speakers with minimum impedances as low as 2 Ohms.
The power supply capacitance increase realized via use of the Black Box or Super Black Box stabilizes current delivery and reduces the impedance interaction of the load. This improves dynamic range, separation, depth, soundstage size and articulation, rendering the musical reproduction clearer throughout the entire frequency range. The amplifier remains unaffected by mains variations and interferences due to the noise filtering characteristics of the capacitors.
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Avtales nærmere
