Selger en ny, ubrukt Ortofon Quintet Black S i uåpnet eske med kvittering og garanti
Selges da jeg har andre pickuper og den ikke vil bli brukt
Pris 5200,-
Nypris 8200,-
Data
Output voltage at 1000 Hz, 5cm/sec. - 0.3 mV
Channel balance at 1 kHz - < 1.0 dB
Channel separation at 1 kHz - > 23 dB
Channel separation at 15 kHz - > 15 dB
Frequency range at - 3dB - 20 - 25.000 Hz
Frequency response 20-20.000 Hz - +/- 1.5 dB
Tracking ability at 315Hz at recommended tracking force *) - 80 µm
Compliance, dynamic, lateral - 15 µm/mN
Stylus type - Nude Shibata on Sapphire cantilever
Stylus tip radius - r/R 6/50 µm
Tracking force range - 2.1-2.5 g (21-25 mN)
Tracking force, recommended - 2.3 g (23 mN)
*) Typical value
Tracking angle - 20°
Internal impedance, DC resistance - 5 Ohm
Recommended load impedance - > 20 Ohm
Cartridge body material - ABS/Aluminium
Coil wire material - Aucurum
Cartridge colour - Black
Cartridge weight - 9 g
Test I Hifi-Choice
Sound quality
With the correct level set, the Ortofon reveals itself to be a highly distinctive yet talented performer. This most clearly manifests itself as a slightly dark tonal balance that helps it to sound refined and powerful...
...What is interesting is that the tonal balance doesn?t restrict the energy at the top end of the frequency response...
...This is a very big and effortless-sounding cartridge....
...Vocals are given presence and detail, but without losing their relationship to the supporting musicians...
Pris 5200,-
Nypris 8200,-
Data
*) Typical value
Test I Hifi-Choice
Sound quality
