Tysk kvalitetsplatespiller i nydelig design. Dette er entry level spilleren til Perpetuum Ebner som har lange tradisjoner med å bygge platespillere i Tyskland. Perpentum Ebner ble revitalisert i 2015 og har siden utviklet 4 modeller. Ta kontakt for mere info. Spilleren kan komme med Ortofon pick-up påmontert på fabrikken ellers så har vi håndlagede alternativer ifra Japanske Shelter. Spilleren kommer komplett med lokk.
The Perpetuum Ebner PE 1010 MKII - our most affordable subchassis turntable with PE TO 2016 tonearm with carbon fiber tonearm tube.
High end turntable with subchassis
Belt drive with synchronous motor
Manufactured tone arm 9.2 inch (PE TO 2016)
XLR and RCA outputs
Description
The subchassis entry into the legendary PE
Perpetuum Ebner PE 1010 MKII turntable is PE's most affordable subchassis turntable. Nevertheless, it offers all the technologies that characterize a Perpetuum Ebner: subchassis drive with two-part main chassis, belt drive and balanced cabling.
Absolute quiet running and precise speed control are guaranteed by a synchronous motor that transmits motion to an aluminum subplatter via a belt. The speed is selected electronically with the speed selector switch on the chassis.
Along with PE 4040, it was the first turntable of the new PE generation in 2016. In the second generation, he received a PE TO 2016 tonearm with carbon fiber tonearm tube, specially developed by PE. In its price range, it offers unique high-end enjoyment.
Included in delivery:
Perpetuum Ebner drive PE 1010 MKII
Tonearm PE TO 2016, 9,2 inch
Phono cable PE phono cable classic
Additional information
Weight 14 kg
Dimensions 34 × 47 × 17,5 cm
Turntable type Subchassis turntable
Drive type Belt with subplatter (aluminium)
Motor Synchronous motor
Platter Material: Aluminium, damped
Weight: 3 kg
Thickness: 24 mm
Tonearm 9“ Carbon Tonearm PE TO 2016
Equipment feet Damped (Sorbothane), height-adjustable
XLR and RCA outputs
Description
Weight 14 kg
Weight: 3 kg
Thickness: 24 mm
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
