http://www.lydogbilde.no/test/hoyttalere/piega-premium-5-2
Jeg fortsetter å redusere overskuddslageret av høyttalere. Jeg har et par med sorte Piega Premium 5.2 som dessverre blir for lite brukt. De har i perioder vært benyttet som bakhøyttalere i kinoen og til dels som fronter i TV stua. Ny pris på disse er vel 41.900,- i sort.
Som alternativ til rent salg kan jeg muligens vurdere en kvalitetsforsterker med digitale innganger, evt en surround forsterker av meget høy kvalitet.
Premium 5.2
The column loudspeakers of this series are highly popular whilst still offering musical and aesthetic enjoyment. Premium loudspeakers come with the legendary PIEGA LDR ribbon and produce an impressive treble range with a fine, silky and crystal clear sound. The most advanced bass chassis with MDS® technology ensure a full-bodied bass performance. The Premium 7 loudspeaker is even fitted with a separate MDS® midrange. All Premium models impress with tremendous, dynamic musicality, even at very low volume levels. They are used where the space available to the loudspeaker is less than the musical demands placed on them. Premium models with a PIEGA ribbon tweeter are available in a wide range of sizes, from the small 30 cm high compact loudspeaker to the meter high column loudspeaker up to the slim-line 160 cm column loudspeaker. The inclusion in the series of two center loudspeakers in different sizes makes the Premium series particularly attractive to multi-channel lovers.
Notice: This product will be delivered with a silver front cover, when the speaker is ordered in silver. On request and extra charge a black cover can be delivered.
Technical detais
Design principle 2 1/2-way-system Floor-standing loudspeaker
Recommended amplifier output 20 200 Watt
Sensitivity 91 db/W/m
Impedance 4 Ohm
Frequency range 34 Hz 50 kHz
Equipment 2 13 cm MDS®-Bass 1 LDR-tweeter
Connection / WBT
Dimensions (H x W x D) 102 x 19 x 22 cm
Weight 21.5 kg
Premium 5.2
Technical detais
Impedance 4 Ohm
Connection / WBT
Weight 21.5 kg
