Velholdt DD klassiker fra Pioneer selges.
11 kg vellydende platespiller. Auto return. Start, stopp og armløft via touch knapper. Digital quartz lock hastighetsstyring.
Ny Audio-Thechnica AT 91 (ATN-3601) pickup montert. Nye arm til pu kabling. Total rens. Smurt lager og arm mekanisme med White grease. Justert flytende oppheng. Polert lokk.
Lydmessig har denne blitt sammenlignet med SL 1200/1210. Så denne kan du enkelt løfte til en høyere lyd liga ved å spandere på den en bedre pu.
Alt virker som det skal. Er koblet opp for test.
Digital stifttrykksvekt følger med ved hurtig hentehandel.
Vipps.
Sakset:
https://www.vinylengine.com/turntable_reviews.php?make=Pioneer&model=PL-600
9/10 by hiwayjunkie
Excellent sounding table, using an Empire Cart.
5/10 by Mikey44
I am the proud owner of 2 of them, purchased them in Germany while in the Army. The best ever, then I also own a Marantz 2500.
10/10 by marktherob2011
I bought this table about a year ago. The auto feature did not work as well as the power would always stay on. The auto feature was fixed with a belt replacement as it was broken. The power button was fixed with a bit of DE-oxit.
This table is super quiet and responds well with the original ACUTEX cartridge. Love the look and sound of this beast.
9/10 by mfsibbald
I bought this table sight unseen on CL, I even had a friend pick it up. Why did I buy this table? because it sat listed for over a month and I thought, well fine for the 50 dollar asking price Ill take it.
What an incredibly well made piece of equipment. Built like a tank, sings like and angel. I would happily have given it 10/10 if the power button was not flaky. Previous post is 100% correct, this machine sat unpurchased because Pioneer also made a PL600 that was a total BPC.
I know many don't care for full auto decks and that's fair but they have a place in my house for their convenience and easy of use. This is one of the best I have ever seen and it gives my manual Kenwood KD500 with Grace tonearm a very serious run for its money. The pioneer gets used more because the end of the record always comes along when my hands are busy in the kitchen or kids bath time or whatever.
Total sleeper table and yes I agree far and away better sound than Technics SL1200 et al, and i am a big fan of the Technics SL series, had several over time.
Bottom line, if you see one GRAB IT! You would easily have to spend 400 - 700 on a well known vintage table to come close to sound and quality.
God and my wife both know I did not need another TT but this time I am sure glad I bought it.
9/10 by pdemara
INTRODUCTION...
Feb 2013,
In my humble opinion this turntable is a total sleeper...
I think part of the confusion about his unit is that there other low cost Pioneer PL-600 models from other years and hence people get confused. This unit is truly awesome.
It's heavy (25 lbs) has super specs and very quiet operation along with a great list of features. And of course what matters most, it sounds great...
FULL SUSPENSION...
It's actually a full suspension turntable and uses stiff springs with damping foam to minimize resonance...
Seems to like my Sure 97xE cartridge as well as a Grado Gold... The tone arm uses a photo coupler to sense arm location which means no interaction during playback. The unit also has auto start when moving the tone arm and an electronic braking system when you manually move the tone arm away from the record... The automatic motor drive disconnects from the tone arm when playing a record and so there's no playback interaction with the automatic portion of the design.
THE SOUND...
I guess what impressed me the most is how quiet this table is... Specs say -78 dbm for noise, which is excellent but as we know, specs can be deceiving.
From my listening tests I can confirm this table is very quiets. It's also excellent at vibration control. Having my sub right next the the turntable causes no feedback issues... As well, no skippy skippy when I walk across my hardwood floor... Something I can't do with my Oracle Delphi...
FIT AND FINISH...
One of the things that caught my eye about this turntable is that it's champagne gold coloured and made from solid metal...No plastic... Pretty much all my other gear is also champagne coloured so this unit looks right at home with my champagne Sony ES gear.
The other great feature is the main buttons seem to be solid and feel like metal. They are also located outside the dust cover which means you can control the turntable without lifting the lid...
ONE ISSUE...
The only issue I had with the turntable was it seemed to have a speed stability problem... Every so often the unit would go out of quartz lock... I cured this problem by realizing all the LED lights in my house are quite noisy so I added and EMI/RFI filter power bar...
Problem solved... Perfect speed control now... LOL, they didn't have switching power supplies back in the late 70's so they wouldn't have ever noticed the issue...
IN SUMMARY...
If you can find one in good condition at a reasonable price (~$200) I would recommend an audition... I know purists think you can only achieve sonic accuracy with a full manual turntable. In my humble opinion, the Pioneer PL-600 turntable breaks that rule.
9/10 by lowlow007
An excellent turntable better than the technics MKII...
Frakt kun Nimber e.l.
Vipps
Vipps.
Sakset:
9/10 by hiwayjunkie
5/10 by Mikey44
9/10 by mfsibbald
9/10 by pdemara
INTRODUCTION...
Feb 2013,
FULL SUSPENSION...
THE SOUND...
FIT AND FINISH...
ONE ISSUE...
IN SUMMARY...
9/10 by lowlow007
Vipps
