Terje-A
Pioneer U-05 Solgt
Denne annonsen er utgått.
D/a konverter
Selges
Tilstand
Brukt
Utløpsdato
Fylke/land
Pris
Kr 3.500
Kjøpt av
HiFi-Lubben
Annonse beskrivelse
Annonse nummer: 215471
Selger min fine Pioneer U-05 DAC/Forforsterker. Fjernkontroll har god rekkevidde. Denne boksen er et columbiegg; hodetelefonforsterker, DAC og forforsterker.
Mye for pengene det her. Hadde det stått et eller annet eksotisk navn på boksen så kunne man lagt til en 0 i prisen:)
D/A Converter Features
? 8ch Parallel Drive with SABRE32 Ultra DAC (ES9016S x 2)
? USB Input (PCM): 44.1 kHz, 48 kHz, 88.2 kHz, 96 kHz, 176.4 kHz, 192 kHz, 352.8 kHz, 384 kHz (16, 24, 32 bit)
? USB Input (DSD): 2.8 MHz, 5.6 MHz
? COAXIAL/OPTICAL/AES/EBU Input: 32 kHz, 44.1 kHz, 48 kHz, 88.2 kHz, 96 kHz, 176.4 kHz, 192 kHz (16, 24 bit)
? Minimum Jitter with Asynchronous Transfer
? Digital Filter with 3 Modes (SHARP/SLOW/SHORT)
? Lock Range Adjust Function for Reducing Jitter by Adjusting Lock Range Accuracy
? DIRECT Mode for Faithful Reproduction of Original Sound
? Audio Scaler for up to 384 kHz/32-bit Upsampling
Headphone Amplifier Features
? Shielded Power Transformer with Independent Winding, Isolated Power and Digital/Analogue Blocks
? Full Balance Circuit for Minimum Noise
? Discreet Circuit Adopted for High-Quality Sound Tuning
? Balanced Headphone Terminal (XLR3/XLR4) x 2 Compatible with Recabled Headphones, Unbalanced Headphone Terminal (STD) x 1
? Fine Adjust Volume Control
? Gain Switch for Using Headphones with Different Impedance
Audio Performance and Various Other Features
? Digital Isolator for Reducing USB Block Noise
? Highly Renowned NEUTRIK Balance Terminals and Machined RCA Terminals
? High-Grade Parts Including Pioneer Custom Power Capacitor
? Variable/Fix Volume Selectable Analogue Output (XLR3/RCA) for Pre-Amp Function
? Phase Switch Feature for Line Output
? Low Centre of Gravity Design with Heavy and Robust Chassis
? Screw-less Flat Design with Aluminium Front, Top, and Side Panels
? Dedicated Remote for Volume and Tone Control
? Front Display for Detailed Source Information
Edit, kjøper kan få med en liten Cypress DCT-4 Analog til Digital Converter hvis ønskelig. Jeg kjøpte den på Stereofil for 695,- Gir muligheter hvis man ønsker å koble til en analog kilde. L/R analog RCA inngang. Både optisk og coaxial digital utgang. Inkl. strømforsyning.
Terje-A
Torget karakterer
Vurderinger (23)
