Strøken Stillpoints LPI V2 platestrammer/demper.
Nypris 9620,-
The LPI v2 is now available in black only
Stillpoints are isolation devices that sit under your components and loudspeakers, effectively decoupling them from the environment on which they sit.
They are manufactured from ceramics and the highest grade stainless steel available and as a result will last for many lifetimes and see you through countless system upgrades.
By installing Stillpoints under an electronic component like an amplifer (or a speaker) you are effectively eliminating a direct path between the component and whatever surface it sits on and as a result you mechanically lower the noise floor.
By doing this you increase dynamics, heighten transients, increase the amount of air and space resulting in a much more musical and natural presentation. You will get a benefit from just putting Stillpoints under 1 component in your hi-fi, but when you float the entire system a scary thing happens with the presentation. I can’t recall doing a demonstration of Stillpoints which hasn’t resulted in someone being amazed with the results, several incredibly sceptical customers have almost become unofficial brand ambassadors, waxing lyrical about the benefits of Stillpoints online!
The LPI V2
Turntables and vibrations are not good bedfellows!
Stillpoints like Ultra SS or Ultra 5 underneath an turntable bring of the typical Stillpoints benefits, but the LPI has been specifically designed to sit on the spindle of your turntable covering the label of the record. This basically takes care of all of the nasty micro vibrations on the record itself, increasing resolution making reproduction clearer, cleaner, more delicate, more open and life like.
Nypris 9620,-
The LPI V2
- Originalemballasje
- Ja
- Orig. kvittering
- Nei
- Forsendelse
- Kan sendes
