100% strøkent effekttrinn.
Spiller flott og dynamisk, med riktig god punch. Er spesielt god match mot blandt annet Dali, System Audio og Klipsch!
Output Power: 120W per channel into 8 Ohm; 200W per channel into 4 Ohm
Inputs: XLR, 2V for 120W into 8 Ohm; RCA, 1V for 120W into 8 Ohm
Other Inputs: 4 to 12V trigger
Frequency Response: <10Hz - 100kHz, -3dB THD: <0,08%
Signal-to-Noise, line: -100dB
Input Impedance: 11k Ohm Output Impedance: <0,03 Ohm Power
Consumption: 800W
Dimensions (WxDxH): 430 x 385 x 140mm
Weight: 20 kg
Kan selges til redusert pris med matchende effekttrinn.Inputs: XLR, 2V for 120W into 8 Ohm; RCA, 1V for 120W into 8 Ohm
Consumption: 800W
Weight: 20 kg
