Ingeniøren
Project Phono Box SE mk2 - RIAA Solgt
Denne annonsen er utgått.
Analog avspilling
Selges
Tilstand
Brukt
Utløpsdato
Fylke/land
Buskerud
Pris
Kr 1.000
Kjøpt av
vsk
Annonse beskrivelse
Annonse nummer: 80031
Helt strøken MM/MC Sølv Riaa fra Project som på bildet. Spiller nøytralt og oppløst - av de bedre i denne prisklassen med mange innstillinger.
Kan sendes mot kjøpers risk og kostnad - har emballasjen. Betaler du forskudd så tar jeg frakten :)
Data fra produsentens side:
The Pro-Ject Phono Box SE II is a totally new design that lifts the performance to an even higher level. a premium chipset, a beefier power supply and the highest grade components form the basis of this audio marvel. it uses five parallel oP-amps for each channel. using SmD technology, the signal paths are reduced dramatically. the result is optimum sound quality and minimised levels of noise and distortion. Mini switches are used to adjust capacity, inductance and subsonic filtering. Phono Box SE II enjoys a clear sonic advantage over the standard Phono Box II.
Preamplifier for MM or MC with switches on the rear panel.
Impedance switch for MC cartridges.
Capacitance switch for MM cartridges.
Dual-mono architecture.
Ultra low-noise ICs.
SMD technology.
DC power possible (e.g. with rechareable batteries).
Input impedances, MM
12, 220, 340, & 440 pf/47 kohm
Input impedances, MC
17, 18, 20, 22, 69, 100 & 220 ohms/120 pF
Gain, MM
40 dB
Output voltage (MC input)
300 mV / 1 kHz at 0.3 mV / 1 kHz
Gain, MC
60 dB
Noise floor, MM
95 dB (100 dB - A weighted)
Noise floor, MC
75 dB (80 dB - A weighted)
THD MM
0.03%
THD MC
0.1%
RIAA-equalisation curve accuracy
20 Hz - 20 kHz / max. 0.3 dB
Subsonic filter
at 18 Hz with 24 dB / octave
Outboard power supply
16 V / 1.000 mA AC, suitable for your country's mains supply
DC operation with battery
Power consumption
16 V / 180 mA AC
DC power source
from ±12 to ±18 V DC
Dimensions
103 x 72 x 144 mm
Weight
1.05g without power supply
Ingeniøren
Torget karakterer
Vurderinger (7)
