En fantastisk High-End RiiA fra PS Audio. Denne har fjernkontroll for valg av motstand og gain på MC-pickup. En utrolig nyttig funksjon å kunne sitte i godstolen å optimalisere ulik motstand og gain til den enkelte LP.
Test Stereophile:
"I recommend a listen to the Stellar to anyone in the market for a new phono preamp, regardless of price. I don't think I've ever written that before. Like darTZeel's clever engineer Hervé Delétraz, Myers designs using a deft combination of technical knowhow and careful listening, more interested in the sonic outcome than in getting the absolute best measured performance. In my view, that's a winning approach.
Footnote 1: As you can see in the measurements section, JA called the RIAA response "superbly accurate."
Les hele testen her:
Omtale 1:
"I had time to swap out my Gold Note for my Stellar Phono Pre and after all connections were made, I switched inputs from CD to Phono and I heard NOTHING. I got worried thinking the Stellar had a problem even though I was certain I connected everything correctly. I started Clapton Unplugged and WOW !! This wonderful sound came from the BLACKEST background I have EVER heard in a Phono Pre (and I have had MANY) Don't know HOW you could achieve the kind of QUIET I heard (or NOT heard
I only care that you did and it sounds AMAZING !!
- Tom Allen"
Omtale 2:
"How did they pull this off?
I wrote James and told him PS Audio should be PROUD!!! I am impressed and that is simply not easy to do at this stage of my audiophile path. Bravo gentlemen for making one of the top 3 SS phono stages I've heard, the others being the SPL Phonos and the iFi iPhono 2 although the SPP is better than the iPhono but at 5 times the price I would hope so
The SPL Phonos just does things dynamically with the London that I've not heard another stage do. This is a golden age for phono stages when a company can build something that sounds as good as the Stellar at that kind of price. Build wise, sound wise, I actually don't know how they pulled it off."
Test Stereophile:
Omtale 1:
- Tom Allen"
Omtale 2:
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
