Momentum er svenske Regals innstegsserie. Høyttalerkablene i Momentum-serien benytter en form for Litz design (multi-strand) med Regals unike Zero teknologi for å redusere isolasjonsmaterialets negative innvirkning på lyden.
Tester gjort av våre kunder og oss indikerer at dette er en kabel med svært gode egenskaper til en, i high-end sammenheng, overkommelig pris. Kablene fremstår som transparente og velbalanserte. Hjemlån forut for et eventuelt kjøp er mulig.
Pris: NOK 22 338,- (for 1 par på 2m lengde, øvrige standard lengder er 2.5m, 3m og 4m) (kan termineres med banan-banan, spade-spade eller spade-banan/banan-spade)
Frakt: Gratis (ved hjemlån dekker vi fraktkostnader 1 vei)
NB! Annonsebildet viser kun 1 av 2 kabler da de er pakket i hver sin eske.
Produktside: Zero² Speaker Momentum
Vår artikkel om Regal: Regal Audio kabler hos Gjallarhorn
The Zero² Speaker Momentum combines Zero technology (patent protected) with an 18-conductor modified Litz construction to reduce the cable inductance to such an extremely low level where it is no longer possible to hear any impact on the sound. With this level of low inductance, the playback system can release the full potential of the recording. The information in the recording will be transferred to the speaker as accurate in timing as is physically possible. The inductance is ~0.05 uH/m.
Zero technology provides transparency and openness in the sound by removing the impact of the insulation material. This improves tonal qualities as well as transient response and micro details. Once experienced, the level of performance is very addictive. Zero technology is about an exceptional experience of clarity, effortless and harmonic richness.
During the development of our speaker cable, we did lot of research in state-of-the-art technologies. During electromagnetic field simulations of market leading design concepts, we saw a new way to optimize the geometries and the design. A new solution that has never been seen before.
Some of this background work is summarized in the article about speaker cables.
- Gold over silver plated OFC connectors
- Patented Zero technology
- 2500+ Hyperfilament cable
- Fully symmetrical geometry
- Cross section area 5.0 mm2
- Very low inductance 0.08 uH/m
- Single layer guard design
- Length options: 2.0, 2.5, 3.0 & 4.0 meter
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
