Etter en gjennomført overgang til McIntosh MA12000 selger jeg den nesten like kraftfulle integrerte forsterkeren MA7000.
Forsterkeren har vært inne for sjekk hos RJ-elektronikk i Bodø og skal etter sigende være like god som ny.
Forsterkeren ble i sin tid som ny testet av Lyd & Bilde med høyest mulig karakter og anbefaling.
Alt tilbehør følger med, inklusive original emballasje.
Grunnet vekten er det aller mest ønskelig å få gjennomført en handel i Bodø. Kan sendes dersom kjøper arrangerer/ordner transport fra min "dør".
Spesifikasjoner (på engelsk):
POWER OUTPUT
250 watts is the minimum sine wave continuous average power output per channel, both channels operating
OUTPUT LOAD IMPEDANCE 2, 4 or 8 Ohms RATED POWER BAND 20Hz to 20,000Hz
TOTAL HARMONIC DISTORTION
0.005% maximum with both channels operat- ing from 250 milliwatts to rated power, 20Hz to 20,000Hz
DYNAMIC HEADROOM 2.0dB
FREQUENCY RESPONSE
+0, -0.5dB from 20Hz to 20,000Hz +0, -3dB from 10Hz to 100,000Hz
PREAMPLIFIER MAIN OUTPUT (FOR RATED INPUT)
2.5V unbalanced (8V Maximum) 5.0V balanced (16V Maximum)
SENSITIVITY (FOR RATED OUTPUT)
High Level, 250mV unbalanced, 500mV balanced Phono, 1.2 mV Power Amp In, 2.5V
SIGNAL TO NOISE RATIO (A-WEIGHTED)
High Level, 100dB below rated output Phono, 84dB below 5mV input
Power Amplifier, 115 below rated output
INTERMODULATION DISTORTION
0.005% maximum, if the instantaneous peak power is 500 watts or less per channel with both channels operating for any combination of frequencies from 20Hz to 20,000Hz
WIDE BAND DAMPING FACTOR
Greater than 40
MAIN OUTPUT IMPEDANCE 50 Ohms
INPUT IMPEDANCE
High Level, 20K Ohms Phono, 47K Ohms; 65pF Power Amp In, 10K Ohms
MAXIMUM INPUT SIGNAL
High Level, 8V unbalanced, 16V balanced Phono, 45mV Power Amplifier In, 16V
POWER GUARD
Less than 2% THD with up to 16dB overdrive at 1,000Hz
VOLTAGE GAIN
High Level to Rec Output: 0dB High Level to Main Output: 20dB Phono to Rec Output: 46dB Phono to Main Output: 66dB Power Amplifier: 25dB
EQUALIZER CONTROLS
Variable 12dB boost to 12dB cut at 30Hz, 150Hz, 500Hz, 1500Hz and 10,000Hz
POWER REQUIREMENTS
100 Volts, 50/60Hz at 8.0 amps 110 Volts, 50/60Hz at 7.2 amps 120 Volts, 50/60Hz at 6.6 amps 220 Volts, 50/60Hz at 3.3 amps 230 Volts, 50/60Hz at 3.3 amps 240 Volts, 50/60Hz at 3.3 amps Standby: Less than 1 watt
Note: Refer to the rear panel of the MA7000 for the correct voltage.
OVERALL DIMENSIONS (H X W X D) INCLUDING THE FEET AND FRONT PANEL KNOBS AND CABLES
Width is 17-1/2 inches (44.45cm) 9-7/16 inches (23.97cm), 17-1/2 inches (44.45cm) x 22 inches (55.88cm)
WEIGHT
97.5 pounds (44.3 kg) net
130.5 pounds (59.2 kg) in shipping carton
POWER OUTPUT
FREQUENCY RESPONSE
Greater than 40
INPUT IMPEDANCE
POWER GUARD
VOLTAGE GAIN
EQUALIZER CONTROLS
POWER REQUIREMENTS
WEIGHT
- Originalemballasje
- Ja
- Forsendelse
- Avtales nærmere
