startpris: 70000 ( 2TB intern lagring)
Wavelight Server
The Wavelight audiophile music Server – or the WLS – is your perfect source partner for Wavelight/Wavedream dacs, or just any dac, especially if equipped with a I2S input. In addition the I2S output, USB, AES/EBU, SPDIF, and optical output (Toslink) are available.
Functions and outputs
WLS resolves a few important aspects of a modern audio setup. It virtually eliminates the need for a computer holding your core server; will eliminate the need for a strong CPU to perform PCM to DSD transcoding; and eliminate the need for a storage server. All these features are included into a sleek and stylish package, visually matching the Wavelight DAC.
All-In-One
Audiophile
Music Server
Internal structure
The WLS combines a few key elements for server-based digital audio playback: a linear power supply, a low TDP computing system running custom Linux, a highly efficient FPGA / DSP system for audio management.
Linear PSU
Custom Linux
FPGA Audio
Software and user scenarios
The WLS will manage to transcode between formats on hardware level, without overloading the CPU. Therefore, it’s heat and RFI emissions will stay low, without bad influence on audio circuitry.
The WLS has the ability to let you choose from a variety of server software and audio services including Roon, MPD, LMS and so on. There are many use scenarios, the device can be used as core, or can be used as renderer or endpoint.
DSD 512
Hardware
Upsampling
Direct Core
Audio
STORAGE
Wavelight Server was designed to host your music. From a basic 2TB to a maximum of 16TB of internal storage, it can keep internally thousands of music albums in high-quality, uncompressed format. Additionally, WLS has 3 USB ports, where you can connect external storage, and/or a NAS (Network Attached Storage) can be defined as music source for WLS.
Full Drive
Management
Control interface
The WLS has a powerful control interface that can be accessed via local browser or control app. It allows the owner to manage internal or attached storage, select active software or services, select upsampling or transcoding parameters, select I2S output setting for DAC compatibility, rip cd’s to local drives, enable room correction etc.
WLS is fully upgradable and future-proof. Both operating system with services and FPGA (audio hardware) can be easily updatable via internet.
Android
App
Ios
App
Web
Interface
HARDWARE SPECIFICATIONS
SPECIFICATIONS
SOFTWARE SPECIFICATIONS
Current release
Upcoming
Downloads
Get the Wavelight Server
control app
User manual
Rockna Electronics srl, 720145 Suceava, Romania
Rockna Audio © 1999 - 2025 . All rights reserved
Cookies help us improve the services provided. By using our services, you agree to the use of cookies. I agree
To Top
Wavelight Server
All-In-One
Audiophile
Music Server
Internal structure
Linear PSU
Custom Linux
FPGA Audio
DSD 512
Hardware
Upsampling
Direct Core
Audio
STORAGE
Full Drive
Management
Control interface
Android
App
Ios
App
Web
Interface
SPECIFICATIONS
Server side: | 2/4 core low power CPU, 8GB RAM, 2TB – 16TB storage |
Audio engine: | AMD 7 series FPGA |
Clock system: | 2 x CCHD957 clocks |
Power supply: | linear, 2 x toroidal transformers |
Outputs: | I2S, AES/EBU, SPDIF, TOSLINK, USB(no upsampling on USB) |
Input: | Ethernet(LAN) |
Current release
Roon Server |
Music Player Daemon (MPD) |
Roon Bridge |
UPnP AV Renderer |
OpenHome Renderer |
HQPlayer NAA |
Airplay Renderer |
LMS core |
CD Ripping |
Room correction software |
Direct streaming services |
Radios |
control app
User manual
To Top
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
