Butikk SALG 25% avslag - Dared Uranus
Integrert forsterker
Selges
Tilstand
Brukt
Utløpsdato
Fylke/land
Rogaland
Pris
Kr 18.740
Annonse beskrivelse
Annonse nummer: 226247
JANUARSALG: Vi har nå Januarsalg og kjører med 25% avslag på et utvalg av våre produkter.
Til denne prisen finner du ikke bedre rørforsterker.
Dared Uranus er en kraftfull og elegant rørforsterker som byr på fantastiske muligheter. Her får du kraft, eleganse, balansert innganger, platespiller innganger og mye mer i en innpakning. Til denne priser er det ikke mange rørforsterkere som kan konkurrere.
Les testen: "...All in all I find the Dared Uranus a fantastic starting point for serious valve amplification. I would like to have even more ?magic? to the sound, but Dared has opted for better control instead, which might be just as smart. Then you can choose between more speakers, you?re not forced to choose horns or high impedance speakers only. In many ways the Uranus is the Audio Innovation S500 for 2016, it looks good, it plays good, it is well built, and flexible. In the price bracket we?re looking at, you won?t find many valve amplifiers being able to compete, it is that good. "
Les hele testen her: https://rognlien.wordpress.com/2017/01/01/space-truckin/
Description
Characteristics:
  • Line Input
  • XLR Input
  • MM Phono Input
  • 3.5mm Input (Located at Front Panel)
  • Direct Power Amp Mode
  • Full Function IR Remote Control
  • Power Tube Bias Adjustment (Located at Top Panel)
  • Power Tube can be replaceable by matchable pair of KT-100, KT-120, KT-150
Specifications:
  • Max. Power consumption: 300W
  • Power Supply: AC115V/230V 50-60Hz
  • Power Output: 50W x2 (Tube: KT-88)
  • Output Impedance: 4ohms or 8ohms
  • Frequency Response: 20Hz-50kHz(5W)
  • Distortion: 0.1%(10W)
Line Input Stage:
  • S/N Ratio: 86dB
  • Input Sensitivity: 300mV
  • Unbalanced Input Impedance: 80kohms
  • Balanced Input Impedance: 95kohms
Phono Stage:
  • MM Impedance: 47k/68pF
  • MM Input Sensitivity: 3.5mV
  • S/N Ratio: 78dB
General:
  • Tubes: KT-88 x4, 12AX7 x2, 6SN7 x2
  • Dimensions: 430x350x180mm (LxWxH)
  • Weight: 30kg
Moet Audio
Torget karakterer
Vurderinger
Andre annonser av Moet Audio
