Vi selger en Simaudio MiND streamer (MOON intelligent Network Device) som er tatt i innbytte fra en kunde. Enheten kan ifølge Simaudio oppgraderes til siste utgave av MiND (MiND 2) og vil da være Roon Ready.
Bruktpris: NOK 9 000,-
Frakt: Kan hentes på vår adresse eller sendes med Posten (uoriginal emballasje vil måtte benyttes)
Produsenten skriver:
Compatibility
Compromises between sound quality and functionality have all been eliminated. Apple and Android smartphones or tablets become the ideal remote control for a MOON system, providing access to music from your computer(s), NAS, mobile devices and various internet based music services. This is what streaming music is all about!
Easy connectivity
The MiND outputs a digital audio signal (Toslink, SPDIF, AES/EBU) intended as an input to any Digital-to-Analog converter. It allows for either a very high-performance or an entry-level system to reach their maximum sonic potential. The addition of Bluetooth® aptX™ audio support provides easy connectivity with your wireless devices.
SimLink™
The SimLink™ connection allows for control of any SimLink equipped MOON system, enhancing ease of use, without having to use the IR remote. The MiND App can adjust the real volume control of a MOON system rather than using the most common digital attenuation method. This maintains the true fidelity of the music at any volume setting. Finally, there are front panel LED indicators for both the current track’s sampling rate and the active input type – network or bluetooth.
Stylish
The MiND is housed in a stylish half size chassis and is the ultimate portal to an unlimited world of great sounding music; an engaging experience that will keep you listening to music longer.
Design features
UPnP Renderer (Universal Plug & Play).
DLNA 1.5 Compatibility.
Online content from TuneIn and other “Music Services”.
Local playlists, gapless playback & silent track scanning.
Supported file formats: Wave, FLAC, FLAC HD, AIF, AAC, ALAC, MP3 (vbr/cbr), WMA-9 and OGG Vorbis, up to 24-bit/192kHz.
Inputs: 100Base-T RJ45 Ethernet interface, IEEE 802.11 b/g/n Wi-Fi interface and Bluetooth® Qualcomm® aptX™.
Digital outputs: SPDIF, TosLink & AES/EBU. • Encryption support for WEP, WPA and WPA2 Wi-Fi.
iPhone, iPad, iPod touch & Android compatible control software.
Zone selection and permanent zone naming.
Independant control for each zone with SimLink™ equipped MOON Preamplifiers or Integrated Amplifiers.
Product features
Remote Control
Full-Function CRM-3
Shipping weight
7.0 lbs. / 3.1 Kgs
Dimensions (width x height x depth)
7.0 x 3.0 x 11.0 in.
17.8 x 7.6 x 28.0 cm.
Omtaler
https://hifiandmusicsource.com/2017/03/moon-neo-mind-review/
https://www.whathifi.com/moon/neo-mind/review
Compatibility
Easy connectivity
SimLink™
Stylish
Design features
Product features
Remote Control
Full-Function CRM-3
Shipping weight
7.0 lbs. / 3.1 Kgs
Omtaler
- Originalemballasje
- Nei
- Orig. kvittering
- Nei
- Forsendelse
- Kan sendes
