mBPS-d2s is an intelligent battery power supply for dX-USB HD/ tX-USBexp/sMS-200 and others.
The mBPS-d2s houses two batteries. While one battery provides power, the other charges and the mBPS-d2s switches between these functions automatically. So all you ever have to do is plug it in and connect it to the device you want to power, there are also 2 types of DC power cables available, UPOCC copper cable(30cm) is including as the standard accessory.There are a series of pairs of LEDs on the unit?s front side showing output status, charge status, and low bat status. The unit is powered with an included external 9V supply that plugs into your wall outlet.
Key Feature
Dual Battery Power Supply
Ultra Low Noise Regulator
Automatic Charge&Output Battery Power
Indicate Operating status
Specification
Power input : 5.5mm x 2.1mm DC jack
Voltage : 9Vdc
Current : 1.5A
Power output : 5.5mm x 2.5mm DC jack
Battery output voltage : 6.5Vdc ~ 8.4Vdc
Output voltage Range : 6Vdc ~ 9Vdc
Current : 1.5A
Battery charge
Charging current : 0.65A
Charging voltage : 8.4Vdc
Max charging time : 6 hour
Battery protection auto recovery
Protection
Input over current
Output short
Battery over voltage
Battery under voltage
Dimension
105 x 53 x150 (mm)
Key Feature
Specification
Voltage : 9Vdc
Current : 1.5A
Current : 1.5A
Battery charge
Protection
Input over current
Output short
Dimension
105 x 53 x150 (mm)
