fraiser
Tannoy Glenair 15 Solgt
Gulvhøyttalere
Byttes
Tilstand
Brukt
Utløpsdato
Fylke/land
Akershus
Pris
Kr 30.000
Annonse beskrivelse
Annonse nummer: 231629
Veldig pent tatt vare på Tannoy Glenair 15 selges / byttes i høyttalere i ca samme prisklasse..
Ønsker ikke å sende, men kan møtes på rimelig avstand fra Oslo..
Recommended amplifier power: 50 - 225 Watts
Continuous power handling: 135 Watts RMS
Frequency response: 32Hz - 25kHz -6dB
Sensitivity: 95dB (2.83 Volts @ 1 metre)
Nominal impedance: 8 Ohms
DRIVE UNITS
Dual Concentric™ high frequency 33mm (1.75”) aluminium alloy dome with Tulip WaveGuide™
Dual Concentric™ low frequency 380mm (15.00”) treated paper pulp cone with HE twin roll fabric surround. 52mm (2.00”) edge wound voice coil
Dispersion: 90 degrees conical CROSSOVER
Frequency: 1.1kHz
Type: Bi-wired, hard wired passive, low pass 2nd order LF, 1st order
HF CONSTRUCTION
Enclosure type: Twin rear ported
Volume: 115L (4 cu. ft.)
Dimensions: 1100 x 460 x 558mm
(43.50 x 18.00 x 22.00”)
Weight: 45kg (99 lbs)
Finish Cherry veneer with solid cherry trim detail
MSRP: $10,000/pair
Originalemballasje
Nei
Orig. kvittering
Nei
Forsendelse
Avtales nærmere
fraiser
Torget karakterer
Vurderinger (10)
