Flott kabel selges da jeg er over på rør og rca..
Kabelen er XLR
Fra Soundstage test:
Of special note is the RSC Air 110 AES/EBU cable, which is the very best cable of its type that I've used. I've always known that the type of digital connection makes a greater difference to the overall sound produced than the cable used, and AES/EBU connections are generally the darkest-sounding and consequently the most software friendly too. The RSC Air 110 AES/EBU cable sounds more linear than all the other cables I've heard, seemingly mixing the various traits of the connections themselves: AES/EBU's friendliness, AT&T's speed and detail, coaxial's middle-of-the-road position. The RSC Air 110 is detailed and relaxed at the same time; it's the best-sounding AES/EBU cable that I've used.
Kabelen er XLR
- Originalemballasje
- Nei
- Orig. kvittering
- Nei
- Forsendelse
- Kan sendes
