Moiz Audio
Butikk Tune Audio Marvel -DEMO
Gulvhøyttalere
Selges
Tilstand
Brukt
Utløpsdato
Fylke/land
Pris
Kr 30.000
Annonse beskrivelse
Annonse nummer: 227826
oppdatert brukt-demo liste:
( brukte, demo-brukte gjenstander selges "as is")
Marvel er en to-veis hornhøyttaler basert på en modifisert fosetx bredbåndselement og tractrix horn. Følsomhet 97 db/ 1m og nominell impedans på 8 ohm.
Det som kjennetegner Marvel er følgende
- Spiller utrolig dynamisk
- Marvel er nøyaktige og homogene i frekvensresponsen
- stemmegjengivelsen er meget ufarget.
- Bassgjengivelse er rask og kjapp med dynamikk.
- Lydbildet er stort, og strekker seg langt utover høyttalarne.
- Diskantnivå kan justeres.
- Passer perfekt med lav-watt /Flea watt forsterkere. Minimum 2 watt.
Info fra produsent:
High quality 8" wide range driver for low & mid frequencies modified in house and 1" compression driver with titanium diaphragm for high frequencies.
MARVEL, a two way design, compact enough to house a back loaded bass horn driven by a wide range 8" driver. Bass horn fires to the floor and it's build of grade A Baltic birch plywood. Mid frequencies are radiated directly by the cone while the high frequencies are handled by our proprietary epoxy compound tractrix horn.
Crossovers are of 1st order and located on the bottom of the bass horn well away from driver's magnetic fields. All components are hard wired for best contact. All internal wiring are custom made of high purity OFC copper with waxed cotton insulation. Brass bracing parts with felt acoustic isolation are used to minimize vibrations transfer on contacts of the different horns.
High frequencies horn is located on the side of the bass horn mechanically time aligned for a time coherent result. User can adjust the level and beaming of the high frequencies horn to fine tune MARVEL to the listening room and position.
System Sensitivity: 97db
Impedance Nominal: 8ohms
Crossover @ 2500HZ
Recommended Power. > 5watt
Recommended Amplifiers. Low-mid powered tube or solid state with low or no feedback.
Recommended Placement. Near wall or room corner placement is desirable.
Preferred clearance between speakers >1.5 m.
Listening Distance. >2 m.
Dimensions.H149cm, W32cm, L56cm
Weight. 42Kgr each
Høyttalerne er demobrukte. Disse ble kjøpt inn i 2015. Varene selges "as is", med begrenset garanti (ref forbrukerkjøpsloven § 17 og kjøpsloven § 19 første ledd). Eventuelle mangler og mer detaljert info kan du få ved å kontakte meg.
Originalemballasje
Nei
Orig. kvittering
Ja
Forsendelse
Avtales nærmere
Moiz Audio
Torget karakterer
Vurderinger (126)
Andre annonser av Moiz Audio
