2 stk. Vienna Acoustics fl tec 8. left over from a work project.
5,5"
8ohm
50 watt
mid/bass units
Used but working perfectly, small marks around edge of screw holes, besides that visually perfect.
Easy to fit as they have a foam baffle mounted to the back and just need to be fitted in a hole between 120mm -130mm.
New cost is 1200kr pr stk.
Frakt included in price.
5,5"
8ohm
50 watt
mid/bass units
