2stk vifa 8 basser selges,fine og hele element,kun merker etter skruer i skruehull.
meget gode basselementer i vifa p21wo serien.
Data from http://www.thielesmall.com
Brand VIFA
Model P21WO-12-08
Description Cast frame, polypropylene cone and rubber surround
Range / type Woofer
Typical use Undetermined
Recomended enclosure
Series
Manufacturer
Order nr
Production status discontinued
Nom. diamerer [inch] 8
Vas [Liters] 85
Qts 0,3374
Qes 0,39
Qms 2,5
Fs [Hz] 33
Sensitivity [dB] 91
Max Power [W] 70
Power definition
Lower freq [Hz]
Upper freq [Hz]
Rec. Filter freq [Hz]
xmax [mm] 4
Brand VIFA
Model P21WO-12-08
Range / type Woofer
Series
Manufacturer
Order nr
Vas [Liters] 85
Qts 0,3374
Qes 0,39
Qms 2,5
Fs [Hz] 33
Sensitivity [dB] 91
Max Power [W] 70
Power definition
Lower freq [Hz]
Upper freq [Hz]
xmax [mm] 4
