Selger YBA WD202, har blitt brukt av meg som hodetelefon forsterker.
Test: http://www.stereophile.com/digitalp...hone_amplifier/index.html#p2OqG6xZ0gKmQ8fo.97
"Bottom line: I could live with the DacMagic but not the V-DAC, though I can see where some folks might want what the Musical Fidelity offers in terms of sound for price ($299). The DacMagic vs YBA was a closer call; I encourage you to listen yourself, especially since the DacMagic costs $439 less than the YBA. But I'm going with the YBA."
Spesifikasjoner:
D/A Converter: Texas Instruments PCM1796 Asynchronous, USB up to 24 Bit 192 kHz
Digital input word length: 16, 18, 20 or 24 bits
Digital input frequency: 32 kHz, 44.1 kHz, 48 kHz, 88.2 kHz, 96 kHz, 192 kHz
Performance: High performance fixed 24 bit/192 kHz upsampling and conversion.
Ultra high precision re-clocking for virtually jitter free function
SNR: -120dB (XLR)
-117dB RCA
THD & N (20 Hz - 20 kHz): <0.001%
Frequency response: 20 Hz - 20 kHz
Output level RCA: Variable, up to 2V
Output level XLR: Variable, up to 4V (2V per phase)
Inputs: USB, Coaxial, S/PDIF, AES/EBU and iPod
Outputs: RCA, XLR, Headphone (jack type 1/4? 6.3mm connector)
Output level: Variable (0-2 Vrms RCA - 0-4 Vrms XLR)
Digital bypass: Yes - Coaxial
Remote control: Yes
Finish: Black
Dimensions w x d x h: 320 mm x 280 mm x 62 mm
Weight: 3.5kg
Spesifikasjoner:
SNR: -120dB (XLR)
-117dB RCA
Remote control: Yes
Finish: Black
Weight: 3.5kg
