C
Yulong DA8 II Hi-Res DAC / hörlursförstärkare
Denne annonsen er utgått.
D/a konverter
Selges
Tilstand
Brukt
Utløpsdato
Fylke/land
Sverige
Pris
Kr 4.000
Annonse beskrivelse
Annonse nummer: 229283
Säljer min Yulong DA8 II Hi-Res DAC / hörlursförstärkare
4 år gammal,Väl omhändertagen, Skick som ny ,originalemballage ,USB kabel ,elkabel, manuell ,kvitto finns ;Provlyssning går givetvis att ordna .
Finns i Stockholm ,Kan skickas. Email : carlosbarrera11@hotmail.com
Pris : 4,000 Kr. (nypris 8,111 kr.)
Video länk:
Funktioner :
DAC Sabre ESS ES9018
High precision clock CRYSTEK CCHD-950-25-100
Canadian Plitron toroidal transformer
Preamp function (balanced and unbalanced outputs)
Supported Sampling Rate: PCM 32bit / 384kHz and DSD
Headphone Amplifier: Class A
Headphone Amplifier Power: 600Ω: 70mw 300Ω: 150mw 150Ω: 280mw 32Ω
LCD screen: TFT 6cm
Volume control: 80 levels
Different combinations of possible sounds (5 different filters)
Automatic configuration backup
Jitter Reduction Button
Phase reversal button
Case: Aluminum
Native support DSD 64/128/256/512
Teamof the AMANERO Combo 384 Interface digital USB 384khz to I2s / DSD
Specifications:
Frequency response: 20-30kHz to -0.2dB
Signal Noise Ratio: -135dB
THD + N: <0.0002%
Dynamic range:> 130dB
Crosstalk: -135dB
Symmetric Output Level: 4.2V
Power consumption: <30W
Chassis 100% Aluminum
Dimensions: (250 mm X 180mm X 60mm)
Weight: 2.5Kg
Compatible with Mac OS , Windows and Linux (with Kernel UAC2)
Supplied with manual, power cable and USB-B cable
Inputs:
1x Optical
1 x Coaxial RCA
1 x AES / EBU
USB: PCM 16-32bit 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz, 352.8kHz
384kHz DSD64,128 - On Windows DSD256, 512
2 x RCA stereo
2 x analog XLR
Operativsystemstöd : Windows ,Mac OSX Linux with UAC2 compliant kernel.
KS/Wasapi/WDM/ASIO Drivers for MS OS XP to Win10 32-64bit
Class A single end headphone amplifier
Originalemballasje
Ja
Orig. kvittering
Ja
Forsendelse
Kan sendes
Torget karakterer
Vurderinger
