Side 1 av 13 12311 ... SisteSiste
Resultater 1 til 20 av 254
Abonnér på denne tråden
  1. #1
    Hifi-entusiast LA8PV's Avatar
    Nov 2012
    Tagget i
    0 Innlegg
    Ethan Winer utforderer Paul McGowan til debatt
    Mr Winer er lei av BS fra PS Paul og vil ha en offentlig debatt om hva som kan måles eller ikke.
  2. #2
    Hifi-entusiast vrøvl's Avatar
    May 2009
    Tagget i
    0 Innlegg
    Gretne gamle gubber.
    Yamaha WXC-50 - JOB INT - Tannoy XT 8F || Rega Brio-R - Guru Junior
  3. #3
    Hifi Freak Distinctive's Avatar
    Dec 2006
    Tagget i
    2 Innlegg
    Album
    100% enig med Paul McGowan i absolutt alt!
  4. #4
    Hifi Freak Balle Clorin's Avatar
    Jun 2012
    Tagget i
    0 Innlegg
    Yokii Yokiiiiiiiiiiii,..
  5. #5
    Hifi Freak Valfy's Avatar
    Feb 2011
    Tagget i
    0 Innlegg
    Sitat Sitat fra Distinctive Se Innlegg
    Det var et særdeles ukritisk standpunkt. Kun for å fyre i gang litt krangel?
    AMR DP-777 SE
    Plinius SA-103
    Klipsch Cornwall III
    The trouble with ignorance is that it feels so much like expertise
  6. #6
    Dec 2006
    Tagget i
    2 Innlegg
    Album
    Sitat Sitat fra Valfy Se Innlegg
    Nei, genuint ærlig utsagn ut fra egen erfaring.
  7. #7
    Hifi Freak svart-hvitt's Avatar
    Jan 2015
    Tagget i
    2 Innlegg
    PS Audio skriver:
    «Getting the power from the wall receptacle to your equipment is a critical link that is often times overlooked. The AC5 is our second best power cable providing a low noise, low impedance path for the AC power to connect your equipment to either a Power Plant AC Regenerator or the wall outlet in your home. Improvements to both audio and video performance are dramatic.»
    Kilde: https://www.psaudio.com/products/ac5-power-cable/
    Og f.eks. dette:
    «Eliminate noise right at the source. Our Noise Harvester is a parallel noise elimination device. Plug it into any AC outlet and it collects line noise and converts it to harmless light. Similar plug-in noise reduction devices simply place a capacitor across the AC line which only shunts line noise from hot to neutral but does not eliminate it. Only a Noise Harvester collects and stores the noise in a capacitor and when enough energy is available, discharges all the unwanted noise into light and it’s gone forever.
    Most power conditioners attempt to isolate your equipment from all the power line noise, but they cannot eliminate or remove power line noise. Only the Noise Harvester removes AC noise and converts it to another form of energy, light. Give your power conditioner a nice head start by lowering your noise floor in the first place.»
    Kilde: https://www.psaudio.com/products/noise-harvester/
    Påstandene fra PS Audio er udokumenterte (det burde være enkelt å dokumentere effekt, men dokumentasjon uteblir alltid) og ingen seriøse ingeniører skjønner hva som er poenget med disse produktene.
    Hifi kan være en fin hobby, men jeg tar ikke munnen for full når jeg sier at slike tulleprodukter bringer hobbyen i vanry.
  8. #8
    Bransjeaktør Orso's Avatar
    Nov 2008
    Tagget i
    2 Innlegg
    Vanskelig å vite om Paul McGowan faktisk mener det han sier eller om han taler det flere ønsker å høre. Mye av det han sier går jo rett hjem i en del audiofile kretser og utfordrer ingenting. Det er populært og salgsfremmende i forhold til egne produkter.
    Representerer lydogakustikk.no
  9. #9
    Hifi-entusiast
    Dec 2013
    Tagget i
    0 Innlegg
    Ja, da har vi fått frem begge syn.
    Så da er vi vel ferdige.
  10. #10
    Jan 2015
    Tagget i
    2 Innlegg
    Sitat Sitat fra storab Se Innlegg
    Nei, det finnes i denne saken bare ett syn; det andre er kynisk marketing som gir opphav til villfarelser hos enkelte. Skulle ønske 2019 ble året da HFS tok et oppgjør med kvakksalverne. Vi lever i en tid med stadig mer fake news, og hvis HFS ikke klarer å skille mellom det reneste sprøyt og fakta, er det trist.
  11. #11
    Æresmedlem HCS's Avatar
    Feb 2007
    Tagget i
    3 Innlegg
    Sitat Sitat fra svart-hvitt Se Innlegg
    Er det slik nå, i 2019, at vi har tilgang på ALL viten rundt det å lytte til musikk ?? Ellers enig , fake news = no good.
    “Music expresses that which cannot be put into words and that which cannot remain silent”
  12. #12
    Jan 2015
    Tagget i
    2 Innlegg
    Sitat Sitat fra HCS Se Innlegg
    Absolutt ikke. Men vi vet alt vi trenger mht. kabler og strøm. Mcgowan snakker ikke om «lytte til musikk», men om effekter som er tallfestbare; og han kommer ikke med et eneste bevis for sine målbare påstander. Merk hvordan du ble lurt av Mcgowan til å ty til den romantiske stråmannen «lytte til musikk», mens Mcgowan snakker om tallfestbare forhold.
  13. #13
    Feb 2007
    Tagget i
    3 Innlegg
    Så faktiske ikke videoen en gang, så enkel er jeg å lure.. . Har alltid sett på PS Audio som av de mer seriøse, men blir sterkt i tvil, etter å ha sett litt på denne...Strøm tror jeg ikke vi vet alt om, ihvertfall tyder det ikke på det her inne. Kabler skal jeg ikke mene noe om, annet enn at det er forskjeller, så får det bli opp til den enkelte å tallfeste dette, teste ut, eller la være..
  14. #14
    Overivrig entusiast TrompeteN's Avatar
    Jul 2013
    Tagget i
    2 Innlegg
    To tullebukker som har alt å vinne på en åpen diskusjon er i det minste underholdende.
    Etter mitt skjønn er ikke den ene det spor bedre enn den andre.
  15. #15
    Jan 2015
    Tagget i
    2 Innlegg
    Sitat Sitat fra TrompeteN Se Innlegg
    @TrompetN, jeg har oppgitt kilder som avkler PS Audio og Mcgowan som en tullebukk.
    Så jeg er nysgjerrig: Hvorfor mener du Ethan Winer er en tullebukk?
    Jeg synes ikke Winer er en tullebukk. Ved å sidestille de to - Mcgowan og Winer - bidrar du etter mitt syn til å legitimere PS Audio og Mcgowan. Det hadde vært bedre for HFS og hifimiljøet om folk med erfaring tok avstand fra det reneste sprøyt i stedet for å latterliggjøre ham (Winer) som avkler kvakksalverne.
    Sånn som uttalelsen din står nå, havner den i tullebukkategorien. Så jeg lurer på hva du egentlig mener.
  16. #16
    Jan 2015
    Tagget i
    2 Innlegg
    Her er en kjapptest av den nevnte Ethan Winer mht. strøm og lyd:
    https://www.prosoundweb.com/channels...signal-cables/
    Ofte skyldes problemer med støy fra ledninger og kontakter at hifi-utstyret er feilkonstruert, i realiteten defekt (vinylkjeden er et unntak, men også der er det mulig å ta forholdsregler). Små selskaper som Schiit (uten at det betyr at alle små selskaper er tvilsomme) har vist seg å levere spesielt utsatt utstyr som til og med er farlig å bruke pga. manglende jording.
    Så ofte lønner det seg å kjøpe lydutstyr fra etablerte merker med godt omdømme blant ingeniører.
  17. #17
    Jun 2012
    Tagget i
    0 Innlegg
    Paul McGowan er først og fremst forretningsmann og lite seriøs som ingeniør og som vitenskapsmann om han tror på det han selv sier. Han har funnet en lukrativ nisje i strømdingser og saker med marginal effekt på lyden. Forsterker og dacene virker nærmest å være biprodukter , men de er sikkert godt laget . Det bør de være til de prisene de tar.
    Videoene er ren markedsføring intet annet. Men det hindrer ikke at han virker som en hyggelig kar..
    Men jeg stoler ikke på ham, da her jeg mer tillit til Benchmar
    https://m.youtube.com/watch?v=9ckp5CYBBjE
    Siste redigert av Balle Clorin; 06.01.2019 kl. 22:04.
  18. #18
    Hifi Freak Terje-A's Avatar
    May 2013
    En leilighet i Moss
    Tagget i
    0 Innlegg
    Torget
    Sitat Sitat fra Balle Clorin Se Innlegg
    Svindlere og lurendreiere er alltid hyggelige karer......
    Bluesound Node 2, Dynaudio Focus 110, Rotel RDD-1580, Sony E90ES, N90ES, KA3ES, K970ES, JA30ES, JA20ES.
  19. #19
    Jul 2013
    Tagget i
    2 Innlegg
    Ok. Det er vanskelig å snakke alles sak så at du tolker det dit er helt ok og lite jeg kan gjøre noe med.
    Det jeg mener er at disse to er veldig polariserte og at sannheten er mer nyansert enn noen av disse representerer.
  20. #20
    Hifi Freak
    Jul 2003
    Tagget i
    0 Innlegg
    Jeg har nevnt det mange ganger før at disse videoene til McGowan grenser til det irriterende pga bullshitnivået. Fint at noen tar tak i det og setter skapet på plass. Flere ganger har McGowan blitt dratt frem som sannhetsvitne og som en autoritet bak tvilsomme audiofile myter i diskusjoner her på HFS. Noe er ikke sant fordi Paul McGowan har sagt det. Å spre misinformasjon på Youtube i stedet for et nettforum gjør jo at det er vanskelig å debattere med han, og utsagnene hans blir gjerne stående som sannheter. Derfor er det fint at noen tar til motmæle og utfordrer den tvilsomme gurustatusen han tydelig vis har i noen kretser.
    Når det er sagt så tviler jeg ikke på at P.S Audio har fine produkter, men de er det forhåpentlig vis noen andre som har konstruert.
    Og Ethan Winer kan til tider også være svært kategorisk og unyansert, men han virker saklig i denne videoen.
Skrive Tillatelser
Om Hifisentralen
    Hifisentralen er Norges største webside innen high-end hi-fi og musikk, og vi har vært på nett siden år 2001. HFS benytter forøvrig samme design og motor som vår nye søster-side: Matpreik.no
Følg oss på sosiale medier:
Facebook Twitter RSS Feed
