Shure SRH940
  • Destiny
    Har bestillt et set Shure SRH 940 etter å ha lest mange meget gode omtaler, og sett at den har fått mye skryt av eiere/brukere av denne hodetelefonen.
    http://www.lydogbilde.no/wp-content/uploads/2011/09/Shure-SRH9401-990x505.jpg
    Trenger kanskje en "god" hodetelefonforsterker i samme prisklasse, og tenkte kanskje noe fra Aune, eller den nye fra Rega. Noen anbefalinger her?
    Har før hatt Sennheiser hd 650, hd 595 og hd 555, har hatt Denon ahd 2000 to ganger, har nå et sett Denon ahd 1100, 1001 og 1000, Rega ear, MF X can V3, John Blue Hydra og Argon ha 1 med standard og forbedra strømforsyning.
    Har fått inntrykk av at Shure SRH 940 er mye lik AKG 701/702, men med litt mer bass og kropp? Jeg håper den ikke blir for lys for min smak?
    Litt innspill ang forsterker og litt om lytteinntrykk tar jeg i mot med takk ;)
    Todd
    Kommer det ny headamp fra Rega?? Spennende i så fall.
    Destiny
    [h=1]NEW Rega EAR Headphone amplifier now available[/h]By Andy
    – July 27, 2012
    The all NEW Rega EAR headphone amplifier is now available and it doesn’t fail to impress.
    Initial impressions are that the Rega EAR headphone amplifier which comes in black or silver has a new smoother and simpler appearance. It just looks better. A high gloss front panel with separate mute and volume controls along with multiple connectivity options means that it can be very easily integrated in to studio, home or office use.
    The Rega EAR also feels light and compact. Measuring just over 17cm wide and 4.5cm high the unpacked weight is around 0.8Kg. It just looks good!
    What’s important is the actual performance of the Rega EAR amplifier as no matter how good a product looks it has got to deliver. Rega have a reputation of designing and manufacturing iconic British made Hi-Fi products so every time Rega update a product there has got to be an improvement.
    We are pleased to report that the Rega Engineers haven’t failed to impress on this front as well. A completely new surface mount PCB layout based on the Rega Brio R amplifier has been installed. The performance really is exceptional.
    Hooked up to a pair of Grado RS2i headphones the Rega EAR demonstrated that by investing in quality components such as a pair of complementary Darlington output transistors, Polyester film and Nichicon FG capacitors Rega have produced their best headphone amplifier to date.
    To achieve this the power supply and noise reduction to the Rega EAR have been worked on. A low noise fully regulated power supply has been installed which was based on the very successful Rega Brio R amplifier along with the use of an external mains transformer.
    Another reason why the performance is so good is that the EAR amplifier is based on the design ideals of the ‘cascaded emitter follower output stage’ along with tried and tested manufacturing methods to produce a very reliable headphone amplifier. All of the Rega Headphone amplifiers are produced in Southend by a team of highly experienced engineers. It’s this type of experience that produces such a good product and all for £198.
    Any questions you can get in contact with us by clicking here or if you want to buy your Rega EAR now with FREE delivery just click here.
    atonal
    Friedrichstadt
    Hei, Destiny!
    SRH-940 er fine klokker og jeg synes de er spesielt fine på stemmer. 940 regnes som lettdreven, men den fortjener en god forsterker, da blir lydbildet mer homogent eller "analogt". 940 kan være litt frempå i lyden og de er nådeløst avslørende på produksjon. Etter min mening fungerer 940 best på "varmtklingende" og "tilbakelent" utstyr. Jeg testet den med en Aune-sak, det synes jeg ikke var en god match, ble for skarpt og frempå. Aune har kommet med en rør-amp som kanskje kan fungere bedre. Jeg bruker 940 med min RME-dac, det fungerer bra. Ellers koblet jeg den opp med Mbare sin DIY rør-amp for en stund tilbake, det låt veldig bra!
    Mvh. a.
    Destiny
    Hei, Destiny!
    Mvh. a.
    Takker for svar atonal, de har fått masse skryt så jeg tok sjansen på å prøve et sett :eek: håper de ikke blir for lyse til min smak, men tror de skal bli bra med passende amp.
    Destiny..:)
    Destiny
    Da er Shure SRH940 henta på posten og står nå til innspilling, men måtte jo ha en sniklytt :rolleyes:og førsteinntrykket var faktisk bedre enn forventet, diskanten virka veldig ren og luftig med fin utklinging på symbaler, mellomtonen virket å være veldig gjennomsiktig med veldig bra gjenngivelse av vokaler, og bassen var absolutt tilstede.
    Detta blir spennende ;)
    Destiny..:)
    CDWMcInSpots
    Bergensregionen
    Tidligere HFS-innlegg
    Takk for ny tråd. Jeg har ganske lenge tenkt at vi bør ha en slik.
    Korrekt produktnavn er Shure SRH940 jfr. Shures produktside.
    Vi skrev om Shure SRH940 i Den store hodetelefontråden i fjor høst:
    Summert i et nøtteskall, oppfatter jeg på mange måter Shure SRH940 som et lukket alternativ til/en lukket AKG K 701.
    Senere har morpheus skrevet en del innlegg inkl. om modifikasjoner (listen er ikke nødvendigvis komplett):
    Destiny
    Flotte innspill som alltid CDWMcInSpots :)
    Destiny..:)
    Morpheus
    Jeg hadde Shure 940 og var veldig begeistret for dem. Jeg klarte dessverre å ta knekken på dem under et op-amp bytte... Brukte dem med min modifiserte M-Stage amp. Jeg har planer om å koble opp M-Stagen igjen og sjekke hvordan 1440 fungerer på den. foreløpig spiller jeg dem egenltig bare inn.
    Eneste ankepunktet mot 940 var bassen, men den ble en del bedre samt mer 3-D følelsen med rope-modden som jeg har skrevet om tidligere.
    CDWMcInSpots
    Bergensregionen
    "Rope mod" (for grunne hodetelefoner) og lett/slank bunn
    Se innlegget ""Rope mod" for grunne hodetelefoner" i tråden "Enkle komforttiltak".
    Lett/slank bunn følger egentlig implisitt av følgende:
    Destiny
    Ja jeg må vel etterhvert ha en forsterker til Shure RSH940, og med impedans på 42ohm så trenger jeg vel en forsterker med ganske lav utgangsimpedans for å opprettholde forholdet 1-8?
    Er M stagen en god match til Shurene?
    Destiny..:)
    Destiny
    Mine Shure RSH940 står nå til innspilling nede i kjellern, tenkte de skulle få runde minst 100 timer før jeg tok de i bruk, har du noen formening om hvor lang innspillingstid de har Morpheus?
    Destiny..:)
    Morpheus
    tja, vanskelig å svare godt på det spørsmålet egentlig. Handler vel også litt om å rekalibrere ørene. M-stagen var en knall-match med 940. Men du kan ha litt å hente på å spandere gode op-amps. er en lang tråd om matrixen på head-fi. I 9 av 10 tilfeller vil jeg foretrekke PSii over Matrixen, men med Shure er jeg faktisk litt i tvil hva jeg vil anbefale av dem. Mest sansynlig PSii fordi man kan tune lyden med rør. Jeg har planer om å bestille rør til PSii i helgen. Matrixen skal jeg koble opp i morgen og teste med 1440.
    Jeg vet du liker dynaudio og det gjør jeg og! Shurene minner meg litt om dem når jeg tenker signatur faktisk.
    Destiny
    Takker for svar Morpheus :) PSii ? Det ligger en brukt matrix på børsen sø?
    Destiny..:)
    Morpheus
    Vel, nå har jeg hørt litt på Shure 1440 på Matrix M-Stage og får de gode minnene tilbake til 940. Min M-stage er litt modifisert så den låter litt annerledes enn en orginal M-stage. Så langt liker jeg bedre musikken slik den blir presentert fra M-Stagen enn fra PSii med orginalrøret. Det blir litt mye energi for å si det slik når jeg parrer PSii og 1440. Dette var jeg egentlig veldig klar over da jeg valgte 1440, men jeg regner med at med litt rør-tweaking vil det bli full klaff etterhvert.
    Men sakens kjerne er at Shure og M-Stagen har veldig flotte synergier. Jeg har fjernet input-caps på M-Stagen. Med den endringen ble lyden mer "klar og åpen", men det geniale med M-Stagen er hvor lett det er å skifte op-amp (operational amplifier) Samt at konstruksjonen til M-Stagen tillater at man kan kjøre op-ampen i klasse A ved å skaffe seg en brown-dog som er modifisert for dette. Ved denne modifikasjonen begynner virkelig M-Stagen å synge skikkelig!
    Ved direkte sammenligning med Auralic Taurus kom M-Stagen litt til kort i mine ører, men da snakker vi om en forsterker til 5x prisen.
    M-Stagen er bygget som en tanks, og jeg har demontert den flere ganger for lodding ol. Den fungerer som den skal omtrent uansett hva du utsetter den for.
    Jeg gav vel 1700 kr for et par år siden, jeg er ikke oppdatert på hva den koster idag, men 1500kr kan virke som en god pris om den er fint behandlet.
    Går du for M-Stagen må du hvertfall prøve den ut med op-amp i klasse A, det er da ting skjer!
    Her er en link mtp op-amp i klasse A: Burr Brown OPA627AP with Class A Biasing Mod
    Vil til slutt nevne at M-Stagen er en klone av denne: http://lehmannaudio.com.au/amp/line/headphone.html, det er dog visse lydmessige ulikheter.
    PSii=Prosjekt Sunrise II som har en egen tråd.
    atonal
    Friedrichstadt
    Interessant å lese om M-Stage`en som 940-eier, Morpheus. Hvordan er støygulvet/egenstøyen fra denne, tro? Og hvordan er de umiddelbare inntrykkene 940 vs. 1440?
    (Håper det er greit med disse spørsmålene i tråden din, Destiny, hvis ikke får du bare si i fra :) )
    Morpheus
    Støygulvet er generelt meget lavt blir det vel..?. Nå har M-Stagen den fine egenskapen at man kan endre gain-setting mellom 0-10-18 og 20dB. Dette gjør den meget flexibel. Akkurat nå lytter jeg med AKG K550 på M-stagen på 10dB. Når jeg ikke har musikken på må jeg skru opp til 3/4 før jeg hører egenstøy fra forsterkeren og så høye nivåer lytter jeg aldri.
    Jeg opplever Shure 1440 som en oppgradering fra 940 på alle parameter, men vi snakker ikke om kvantesprang. 1440 har større soundstage enn 940, mens 940 spillte litt mer intimt. Begge deler har jo styrker og svakheter alt etter hvilken musikk man spiller og hvilken stemning man ønsker å komme i!
    Kan nevne at jeg svært skjelden hører på rock i forskjellige former. Når jeg lytter på Shurene er det først og frem vokaldrevet musikk eller instrumental eller akustisk musikk.
    Bilde1: Her er et sørgelig bildet av mine Shure 940
    Bilde2: Her er min Modifiserte M-Stage
    Destiny
    Minns å lese at det var skifta op.amper på m stagen på børsen?
    No problem atonal, bare spør i vei du ;)
    Destiny..:)
    Destiny
    Det var en duell i siste Watt mellom Sennheiser HD 700 og Shure SRH1840 og Shure ble best i test ;)
    Destiny..:)
    Destiny
    Da har jeg fått spillt litt musikk gjennom Shure SRH940, og lyden holder veldig høy kvalitet: Lyden er frisk og krisp med god snert på strengeinstrumenter, det er fint rom og lett å skille forskjellige lyder fra hverandre :) mellomtonen er klar og gjennomsiktig, og vokaler og instrumentering står fram klart og tydelig. Jeg syns diskanten er klart definert med en passe dose luftighet, og kan ikke si at det er noen problemer med sibilantlyder e.l.
    Bassen er tørr og presis, men har alikevel tyngde og kraft når det trengs. Eneste ankepunktet så langt er at jeg blir litt varm på øra av putene, her syns jeg andre headsett har vært litt behageligere å ha på over lengre tid, og det er litt dumt for lyden er så innsmigrende at jeg får jo lyst til å høre mer musikk hele tiden, det er litt vanskelig å avslutte lyttesesjonen ;)
    Jeg gir pr nå terningkast 5 på lyd og 4 på komfort. Jeg har da kun lytta med en Sony discman D-NE 300 som gir 5mW +5mW ved 16 ohm.
    Destiny..:)
    CDWMcInSpots
    Bergensregionen
    Dette passer egentlig meget bra med følgende:
    Den fortjener bedre.
    Destiny
    Hei CDWMcInSpots, den skal få bedre ;) men hvor tykt bør tauet være til rope mode ? Vurderer å kjøpe den nye Rega Ear II eller muligens Graham Slee Novo/Solo ?
    Eller så ligger det en brukt Matrix m stage på børsen.
    Destiny..:)
    CDWMcInSpots
    Bergensregionen
    Det vil i hvert fall avhenge av hvor mye plass det er i puten, putens polstring og brukerens smak og behag.
    Morpheus benyttet (deler av) en gammel (påhengsmotor?)startsnor på sin Shure SRH940. Du kan jo benytte det som et dimensjoneringsutgangspunkt.
    Selv har jeg kjøpt inn line med Ø 3, 4 og 5 mm for forsøk med i hvert fall AKG HSD 271 og STAX SR-Λ (Lambda), men det står fremdeles på vent. Det er mulig at noen hodetelefonputer også har plass til 6 mm line. Jeg fant ikke halve mm i den butikken jeg handlet i.
    Line er neppe det eneste man kan benytte. Jeg antar at man også f.eks. kan benytte noen typer tetningslister, O-ringer, kanskje pakninger, selvsagt snorer av lær, en del sko- og støvellisser, osv.
    Destiny
    Da har jeg ropemodda Shurane, jeg valgte flaggline med ø 5mm og det hjalp betraktelig på komforten ;) nå går den opp fra terningkast 4 til 5 på komfort :)
    Lydmessige fordeler? muligens litt mer romfølelse.
    Destiny..:)
    Destiny
    Moro å høre at 940 falt i smak, Destiny :)
    Ja Shure RSH940 er uten tvil et meget godt headsett, og til prisen er det vel nesten å regne som et kupp ;) lyden er meget god, og med ropemodden er også komforten blitt meget god.
    Destiny..:)
    Destiny
    Da har det skjedd litt med hodetelefonanlegget, en Denon DCD F 107 CD spiller er kjøpt inn som signalkilde og mater en Lake People G 103 hodetelefonforsterker, og som signalkabel mellom kilde og forsterker bruker jeg en Chord Crimson pluss.
    Destiny..:)
    Destiny
    The Lake People G103
    The entry level G103 is a very compact unit, measuring 4.25 inches wide, 2 inches tall, and just under 6 inches deep. It should be able to fit just about anywhere. The front panel is exceedingly simple: dual 1/4" headphone jacks, a power button, and a volume knob. That's it. Around back we see an IEC power cable inlet and a pair of input jacks - XLR variety in my case since I have the Pro version.
    intended for driving speakers, and is popular with the DIY crowd for things like Gainclone amps.
    Specs on the G103 are pretty impressive for such a small thing. Of particular note to users of planar headphones is the current delivery into a 50 ohm load: 1130 mW. Gain can be adjusted via internal jumpers to settings of-4 / +2 / +8 / +14 dB to account for any variety of headphone being used. Output impedance is less than 0.1 ohm.
    Destiny..:)
    Destiny
    So how does the thing sound? The first thing that struck me was the pitch black background. I'm not using that term in the sort of nebulous, audiophile way. I mean the background was literally silent, absent any hiss, hum, grit, or other undesirables. This was the case with everything---low impedance or high impedance cans, planar-magnetic headhones, and ultra-sensitive in ear monitors. The channel matching was very tight, with just a barely perceptible imbalance at ultra-quiet levels. Any real world listening gets well beyond that range.
    From there, my listening notes focus on low frequency reproduction. This amp performs far better than the price would suggest. Using headphones with really good low frequency performance (HiFiMAN HE-500, Denon D7000, Unique Melody Merlin), I heard loads of texture and detail. It didn't come across as being emphasized at all, but due to the high amount of clarity it was something that my ear was drawn to. This could probably cause some listeners to refer to it as a "warm" sound. I submit that it's only "warm" in the sense that it shines a perceptual spotlight on the bass quality more than anything else.
    Mids were nice and clear as well---reasonably transparent and open sounding. I believe this is what people tend to refer to as "getting out of the way of the music", as cliche as that may be. Granted it may not have the same level of realism that more ambitious amps can display, but it does pretty well, and for the price I am very satisfied with it. The point at which the budget nature of the design becomes most audibly apparent is in the upper mids and highs. They end up being slower, and slightly "bland" for lack of a better word. It's a subtractive shortcoming which is better than the usual solid state edginess that other budget amps have, but obviously still not ideal. This is another part that could elicit descriptions of a slight "darkness", despite the measured frequency response being totally flat. This was more easily noticed when using higher impedance headphones---a fact that Fried Reim agrees with and attributes to the combination of power supply limitations and lower internal voltage
    Destiny..:)
    Destiny
    Jeg bråkjøpte Lake People G 103 av Sture fra Audio Norge på messa i går, men fikk et åpent kjøp og hvis jeg ikke er helt fornøyd så kan jeg dra inn å bytte den i en annen forsterker ;)
    Tenkte da litt på storebror Lake People G 109
    Destiny..:)
    Destiny
    Internally, the G109 differs from the G103 in some key areas. It features a higher spec toroidal transformer with a larger array of smoothing caps, a premium Alps RK27 pot, and offers three gain choices (-4, +8, +14 dB) instead of four. The business end consists of a classic NE5532 opamp driving a discrete diamond buffer made up of 4 transistors per channel. Output impedance is less than 0.2 ohms. Once again, this is a relatively simple design but very well executed.
    These improvements pay dividends in terms of sound. We keep the excellent low frequency performance, which is actually subtly improved (especially with higher impedance headphones, at high volumes). We get a slightly improved, transparently clear midrange. But this time we get matching quality in the upper mids and highs---the G109 is agile, with transients being more accurately resolved. It's a very neutral sound, and since everything is on the same level it doesn't give that perceived "warmth" of the G103.
    My favorite aspect of the G109 is its universal ability to drive pretty much any headphone in existence. Very short is the list of relatively affordable amps that can swing this much voltage into high impedance loads while delivering gobs of current into planar models (over 2000 mW at 50 ohms), with variable gain and an inky black silent background with even the most sensitive IEMs.
    Of course, this is still a device built to a price point, and as such it isn't intended to be a statement product. Folks looking for really high end performance should be checking out gear from from ECP Audio, Apex Audio, or Eddie Current, just to name a few. In comparison to its upscale Violectric V200 sibling, the G109 is less resolving and isn't as velvet-smooth up top. Nor does it capture that convincingly holographic "you are there" feel. But the V200 is twice the price, and has a host of improvements like double the output transistors per channel and much higher power supply voltage with more regulation. It's impressive that the G109 does so much with so little.
    The Apex Butte is an excellent comparison for the G109. It costs about the same, and in many ways sounds about the same too. Once again the Butte suffers from having a lower quality volume pot, while the G109 has essentially perfect channel balance. From a usability standpoint, I like having the different gain options to play with. When using sensitive headphones, or especially IEMs, I always wish the Butte had more usable range in the volume---it gets really loud, really quickly. Aside from those minor issues, the Lake People and Butte have very few distinguishing sonic traits. I think I hear a touch more upper midrange accuracy on the G109, especially with higher impedance headphones, but the difference is fleeting.
    Conclusions
    The philosophy of headphone amplification, according to Lake People, is simple: high output voltage; high output power; high damping factor due to low output impedance; and low noise through low internal gain. These four essential ingredients are easy to describe but not always easy to achieve. With the G109, and to a lesser extent the G103, Lake People have accomplished those goals. In the process they have matched or even exceeded the already high performance of the Apex Butte, which is a very respectable accomplishment. I highly recommend each amp within their particular price points.
    Destiny..:)
    BunnSolid
    Gata
    Grattis Destiny! Håper du er fornøyd :)
    Destiny
    Tja :rolleyes: både og, den åpner opp headsettet, men pr nå kan den virke litt lys i toppen sammen med Shure SRH940, mulig jeg går opp et snepp, men får la den få noen dager.
    Destiny..:)
    Destiny
    Det er den ubalanserte versjonen jeg har:
    STEREO HEADPHONES AMPLIFIER G103-S
    [TR]
    [TD="class: ttext"]Headphones amplifier with highest transmission quality
    and compact dimensions to drive 2 headphones.
    The PHONE-AMP G93 is optimized to lowest noise and
    distortion.
    The featurs:
    - unbalanced inputs via cinch connectors
    - two gains switchable: +8 / +14 dB
    - NF trammission band exceeds 150 kHz (-3dB)
    - Alps volume control with good channel balance
    and low crosstalk
    - powerful amplifiers
    Because of ist variable gain structure G103 is best
    suited to drive low- to high impedance headphones
    (16 … 600 Ohm)
    The inputs are situated on the rearpanel, they are
    equipped with unbalanced cinch connectors.
    A rotary pot on the frontpanel is provided for level
    control. G103 is equipped with two headphones
    outputs with 1/4" jacks.
    The unit offers a built-in power supply with IEC/CEE
    socket.
    The complete case, front and back panels are made
    of black anodizes aluminium.
    [/TD]
    [/TR]
    Technical Data
    Balanced inputs:2 cinch connectors (L / R)
    Impedance:10 kohms
    Amplifier Channels:2 (Stereo)
    Nom. input level:+ 6 dBu
    Gain:+8 / +14 dB, selectable
    Frequency range:5 Hz ... 150 kHz (-3 dB)
    Dynamic range:> 125 dB (A-wtd)
    Noise:< -98 dBu (A-wtd)
    THD+N:< 0,002 % (800mW / 100R)
    Crosstalk:< -70 dB (@ 15 kHz)
    Max. output level:> 17.8 Veff in 600 ohms = 530 mW
    > 16.0 Veff in 300 ohms = 850 mW
    > 13.7 Veff in 200 ohms = 940 mW
    > 7.5 Veff in 50 ohms = 1130 mW
    > 3.7 Veff in 16 ohms = 890 mW
    Outputs:2 x 1/4" phone jacks
    Internal voltages:+/- 15 or +/- 30 V, selectable
    Power supply:115 / 230 VAC / 8 VA
    Case Dimensions:108 x 49 x 145 mm (W x H x D)
    Front and Back:2 mm brushed Stainless steel
    Case Material:black anodized Aluminium
    Nå har jeg operert den litt ;) har flytta på jumprane og dempa gainet fra +14 til +8. og det hjalp faktisk bra på sibilantene.
    Destiny..:)
    Morpheus
    Veldig hyggelig å ha fått deg inn her i headfi-kroken, Destiny :). Og som sagt; Shure 940 er veldig bra hodetelefoner!! Tipper at Vioelectric V 200 ville vært en meget bra match til de utifra de beskrivelsene jeg har hørt og lest om den! Får snart hørt på den selv :).
    Destiny
    Veldig spennende Morpheus, har tenkt på den selv etter å ha lest litt her inne ;) tilbakemelding ang lytteinntrykk takk!
    Destiny..:)
    Morpheus
    Destiny..:)
    Med forbehold om at jeg som sagt ikke har hørt V200:
    KML har hatt sin v200 noen dager nå, og bruker den sammen med HE 500. I følge han så spiller det "varmt" og "behagelig" uten at han føler deg går på bekostning av detaljene. Shure som har hovedfokuset på mellomtonen og i toppen tror jeg kunnet blitt en flott kombinasjon med V200 siden det antakelig kunnet skapt en god balanse.
    Er egentlig spent på hvordan psii låter med Shure 940. Jeg har akkurat montert inn et nytt rør i psii som landet i postkassen idag. Må virkelig si jeg liker det jeg hører :)
    Ellers venter jeg på Shure 1840 som er utsolgt fra importøren...skal visst komme inn medio denne uken.
