Da kommer progression i stereo også fra Dan D Agostino!
Den blir sikkert å se under Munchen messa.
Tipper det snart dukker opp en preamp i samme serie!
Abundant power is required for realistic sound quality and is a cornerstone of Dan D’Agostino Master Audio Systems’ amplifier design. The Progression Stereo continues this practice. A graceful anodized Aluminum chassis houses a nearly 3,000 VA power supply transformer coupled to 400,000 microfarads of power supply storage capacitance. Paired to this foundation is a fully complementary driver stage, and output circuitry outfitted with 48 power transistors - 24 each for the left and right channels generating an imposing output. The Progression Stereo is conservatively rated at 300 Watts into 8 Ohms and delivers 600 Watts into 4 Ohms, and properly doubles its output again into 2 Ohms, with a 1,200 Watt power output. The essence of live music, dynamic contrasts, are faithfully reproduced with leading edge transients spectacularly depicted
Mvh: Espen L
