Quantum Resonator Conditioner
You can enjoy the following technology:
1、TELOS V3.1, Part screening single-oriented logic, let circuit have the minimum internal impedance, maximum circuit dynamics
2、QRC adopts QNR’s mature phase correction technology, redesigned and adjusted to featured plugin part circuit, increase the circuit to minimize its dynamic losses, customized Danish Duran capacitor, and choose a more accurate resonance IC chip, make it have the accurate active phase compensation.
3、QBT Conductor over-frequency technology, , QRC related metal parts (wiring, fuse, AC seat, socket) both are burning through 0-100 kHz broadband. Trying to reduce the internal resistance of the related power path, make the power transmission have the best bandwidth. Most of all, ABL socket which used QBT up to 42 days-999 hours of the ultimate burning specification.
4、QMT- Broadband average magnetic field, located in the main circuit core of QRC, corresponding to QNR core module, the program initiates0 0-100khz broadband average magnetic field every fifteen minutes, making QRC a unique sound-clear quality!
5、While assembling all the lock points details of the power supply. We used the Japan KANON DTDK-n50ex electronic service Torque screwdriver, use the precise characteristics with an error value of only 0.005. Control the torque of all the lock points to reduce the effects of contact impedance changes.
6、All materials of active circuit board are according to QUANTUM X2 Tuning specification, through two times of -196°C ultra-low temperature cold treatment-36hr (be separated by 12hr each times), dispersing electronic parts welding stress. Average distribution of the solder’s molecular. Make the DIP circuit working more smoothly.
7、TELOS QUANTUM materials- Graphene/Rare Earth/Far Infrared negative ion ore exclusive formula, generating 75-800 cpm far infrared radiation to illuminate the QRC board and IC fuses continuously. Much better for electronic parts’ optimized performance.
8、The whole machine adopts 6061 aerospace aluminum material, which is produced by CNC for 72 hours, and the integrated molding case weighs 16KG, it minimized the negative influence of vibration.
