Lab12 DAC1 Reference
  • Analoglydende DAC basert på TDA 1543 og triodeutgang!
    Lab12 har konstruert en ny NOS-DAC som overgår tidligere konstruksjoner. Den heter DAC1 Reference.
    Produktet har et no-sampling, no-upsampling design kronstruert rundt Philips multibit DAC chiper.
    Lab12 DAC1 Reference har også rørbasert utgangstrinn.
    Info fra produsenten:
    With the ever-expanding market of digital audio, both files and online streaming services, more and more people are discovering the world of digital audio. Furthermore, in the past few years many of the most demanding music lovers and audiophiles have discovered the unique sound of non-oversampling DACs to make the most of their digital audio sources.
    The biggest challenge for any DAC is the sound and not the ‘’numbers’’. Digital by default sounds very different when compared to analog and we at Lab12 have spent countless hours striving for the perfect voicing that resembles the very best qualities of analog. We couldn’t be more proud of our newest creation Dac1 reference. In this new DAC, which is based on the same core and philosophy as the successful and multi- awarded Lab12 Dac1 Special Edition, we pushed the limits even more in all stages, such as power supply stages, digital inputs crucial paths and receivers, jitter reduction etc, in order to reach the closest approach to the original analog sound.
    Dac1 reference uses eight multibit Philips DAC chips in a complex parallel configuration right after an efficient layout digital receiver stage, allied with two dual triodes tubes in output stage. Each and every part has been selected for its sonic value that brings identifiable and coherent benefits to the final sound you will hear. The result is one of a kind emotional and transparent sonic performance. As all Lab12 products, Dac1 reference also comes with two colour choices of glass blasting anodizing finish.
    Specifications: • Power: 210 – 240VAC 50Hz (110 – 120VAC 60Hz) • Power consumption: 70 VA max • Inputs: 2x SPDIF (Coaxial RCA), 1x USB2, 1x spdif (Optical Toslink) • Outputs: 2x RCA, 2x XLR unbalanced (balanced version available) • Frequency response: 20Hz to 20 KHz + 0dB/-1dB • THD: lower than 0.15% • Rated output level: 2.5Vrms • Tube complement: 2x 6922 dual triode • Available Colours: Matt Black, Frozen Silver • Dimensions (WxHxD): 43x11x29 cm • Weight: 7.5 Kg
    veil. Pris: 30900 ( Ta kontakt for beste tilbud!)
    Moiz Audio
    epost: info@moiz.no
    cbarth1
    Arendal
    Denne virket spennende! Finnes det en versjon som er fullbalansert? Hva er evt prisen på den?
    Moiz Audio
    Hei finnes ingen Fullbalansert versjon.. hvor har du sett dette?
    cbarth1
    Arendal
    Leser bare over her: Outputs: 2x RCA, 2x XLR unbalanced (balanced version available)
    motoren
    Flekkefjord
    Denne virker svært spennende :) Hadde vært moro å teste ut i eget oppsett
    Moiz Audio
    versjon med Lundahl OPT er tilgjengelig for bestilling
    Moiz Audio
    Moiz Audio
    Vi får inn en versjon med Lundahl utgangstrafoer neste uke. Pris: 38900 NOK
    Dharmabum
    Denne dac'en er sabla god! Har dere sammenlignet stock power cord vs lab12 knack?
    Nemlonif
    Jeg har hatt DAC1 Reference på hjemlån fra NAT noen dager, og må si det er et svært spennende bekjentskap. Den har spilt seg inn i anlegget, og skaper musikk på en måte jeg knapt har hørt ved digitalavspilling tidligere. Én låt de fleste kjenner, og som er spilt til det kjedsommelige på hifi-messer i inn- og utland, er Lofgren live med Keith don't go. Jeg har aldri hørt strengelyden mer forståelig, kasseklangen mer naturtro enn gjennom Lab12-dac-en. Dac-en er kanskje aller best på akustisk musikk, men den tar alt jeg kaster på den på strak arm, fra redbook 16/44,1 til 24/192. Den er motsetningen av analytisk, men får med seg alle detaljer i en bronseblank brystklang i en sømløs, tredimensjonal lydscene. Og så har den retro-bling-utseendet jeg liker godt ...
    Dharmabum
    Det må være et av de beste dac kjøpene der ute og lydmessig er den veldig naturlig , balansert og analog i klangen!
Moiz Audio
Moiz Audio sine annonser
  • 1
PÅ LAGER IGJEN! Lab12 DAC1 Reference er et imponerende produkt som er konstruert rundt 8 Philips multibit DAC-chips i en parallell konfigurasjon og 6922 trioderør på utgangen. DAC1 Reference...
Burson Audio Soloist Voyager
  • 1
Flaggskip Amp fra Burson Audio er nå tilgjengelig i Norge Dette er en en Klasse-A, symmetrisk Dual Mono design og Fullbalansert . En strømsterk forsterker som leverer 10 Watt i klasse A...
Burson Audio diskret OP-amper: Vivid V7 Pro vs Vivid V6 (forrige generasjon)
  • 5
Andy skifter Vivid V6 opampene i Burson Audio Playmate 2 til nyeste Vivid V7 PRO, og forklarer forskjellene han hører. V7 Vivid PRO op-amps er designet for å oppnå maksimal oppløsning og...
BURSON AUDIO V7 OP-AMPER ! ! ! ! ! !
  • 7
BURSON AUDIO PRODUKTER KAN NÅ OPPGRADERES! Burson Audio's nyeste generasjon av Diskre OP-amper er nå tilgjengelig! v7 serien kombinerer banebrytende kretsløp og overlegen lyd. Den kompakte...
Audiophile.fr tester LAB 12 Gordian
  • 3
Tidligere omtalt hos stereopluss https://viewer.joomag.com/stereo-7-2023/0397186001696598323/p58?short AB12 Gordian er en strømrenser som består både av passive og aktive filtre. Analysekretsen...
SPL Diamond DAC
SPL Diamond DAC
  • 12
SPL Diamond DAC definerer en ny standard for lydgjengivelse, og er designet for de som setter pris på det ekstraordinære. SPL gjengir en rikdom av lyd, feilfri ytelse og uovertruffen dynamikk. Den...
