stemmer det, jeg tenkte på broren som ble skutt i 68Kennedy ble skutt i 1963
Mht tidsforskjellen er det også korrektHusker at det var om kvelden for jeg hadde lagt meg og faren min kom inn på rommet mitt og fortalte om mordet.
Ouch, it hurts!
Ikke i toern håper jeg?!Den Philipsen er jeg spent på å se mer av imorgen! Det kribler.....!
Tore
Nå er jeg jo faen SÅ mye eldre enn dere, såååååhhhhh16 rpm
Du er en klok herre mann HassebasseNå er jeg jo faen SÅ mye eldre enn dere, såååååhhhhh
NESTEN korrekt
Det rette svaret er 16 2/3 rpm eller 16,666 (det halve av 33.333).
Det var hovedsakelig Frankrike, (i hvert fall de, som holdt lengst) som i en periode holdt på med dette for å få Long, longplay på en plateside.
Men akkurat som med R2R, som hadde hastighetene 4,75, 9,5, 19 & 38cm/sek, fandt man ut av, at det var veldig lite "Fidelity"
på den langsomme hastigheten. at dette fort stoppet av seg selv.
Fra Wikipedia:
Evolutionary steps[edit]
Manufacturing vinyl records in 1959
Technology used in making recordings also developed and prospered. There were ten major evolutionary steps that improved LP production and quality during a period of approximately forty years.
https://www.capsnews.org/apn2010-3.htm
- Electrical transcriptions and 78s were first used as sources to master LP lacquer–aluminium cuts in 1948. This was before magnetic tape was commonly employed for mastering. Variable pitch groove spacing helped enable greater recorded dynamic levels. The heated stylus improved the cutting of high frequencies. Gold sputtering in vacuo became increasingly used to make high quality matrices from the cuts to stamp vinyl records.
- Decca in Britain used high-quality wide range condenser microphones for the Full Frequency Range Recording (FFRR) system c. 1949. Wax mastering was employed to produce Decca/London LPs. This created considerable interest in the United States, and served to raise the customer's overall expectations of quality in microgroove records.
- Tape recording with condenser microphones became a long used standard operating procedure in mastering lacquer–aluminium cuts. This improved the overall pickup of high quality sound and enabled tape editing. Over the years there were variations in the kinds of tape recorders used, such as the width and number of tracks employed, including 35 mm magnetic film technology.
- Production of stereo tape masters and the stereo LP in 1958 brought significant improvements in recording technology.
- Limitations in the disc cutting part of the process later generated the idea that half-speed mastering would improve quality (in which the source tape is played at half-speed and the lacquer–aluminium disc cut at 16+2⁄3 rpm rather than 33+1⁄3 rpm).
- Some 12 inch LPs were cut at 45 rpm claiming better quality sound, but this practice was short-lived.
- Efforts were made in the 1970s to record as many as four audio channels on an LP (quadraphonic) by means of matrix and modulated carrier methods. This development was neither a widespread success nor long lasting.
- Efforts were also made to simplify the chain of equipment in the recording process and return to live recording directly to the disc master.
- Noise reduction systems were also used in tape mastering of some LPs, as well as in the LP itself.
- As video recorder technology improved it became possible to modify them and use analogue to digital converters (codecs) for digital sound recording. This brought greater dynamic range to tape mastering, combined with low noise and distortion, and freedom from drop outs as well as pre- and post-echo. The digital recording was played back providing a high quality analogue signal to master the lacquer–aluminium cut.
Vis vedlegget 794107
Det var litt av et eksempel på 16 RPM-plate du hadde valgt!Nå er jeg jo faen SÅ mye eldre enn dere, såååååhhhhh
NESTEN korrekt
Fra Wikipedia:
Swaggart selv fikk jo kraftig skudd for baugen nettopp for, la oss kalle det, fravær av fidelity, eller infidelity ...Ha ha...
Ja, første bilde jeg fandt, men beskriver mye vel, hva dette var bedst til ....... tale mere enn musikk
"Fravær av fidelity"....... dagensSwaggart selv fikk jo kraftig skudd for baugen nettopp for, la oss kalle det, fravær av fidelity, eller infidelity ...
HAN er flink på GOOGLE den MANDENDu er en klok herre mann Hassebasse
Pas nu på, at den "Googleorakel" skrivemåten IKKE ta´r overhåndHAN er flink på GOOGLE den MANDEN
BTW: den platen på bildet kan jeg ikke spille, da jeg har meldt meg ut!
Du glemte; TT veier som en elefantp Elefanter glemmer aldri.
q TT glemmer aldri.
pq TT er en elefant.
Mvh Erasmus Montanus
Ja da, den skal ingen steder. Ser den trenger en ny reim, da den ligger som smeltet lakris under tallerken. Jeg har noen reimer, så jeg kan få den opp og gå allerede. Jeg vet ikke om denne kan kalles for en mellomhjulsspiller, men noen gummihjul er det. HarDen Philipsen var utrolig fin, og sikkert sjelden,TT. Den må du ta godt vare på!
Tore
