Atlantis Labs AT 13 pro, og AT 21 pro Desember tilbud !
Atlantis AT 21 pro
Impedance: 4 Ω
Sensitivity: 96 db
Woofer: Face to Face Double Woofer 21cm and 13cm
Eighteen Sound
Tweeter: 1-inch Compression Driver Eighteen Sound
90×90 Degrees Atmos-type Horn
Frequency Response (±1 db): 35 Hz - 20 KHz
Power Handling: 250W
Peak Power: 500 W
Recommended All types of Amplifier Power: 6 - 400 W
Cable: Esprit Audio
41 000 kr. 15 % rabatt = 34 900 kr.
Atlantis AT 13 pro
Impedance: 8 Ω
Sensitivity: 92 db
Woofer: 13cm Eighteen Sound
Tweeter: Textile Dome Tweeter
Frequency Response (±1 db): 40 Hz - 22 KHz
Power Handling: 125W
Peak Power: 250 W
Cable: Esprit Audio
Bass-reflex Port: Adjustable
*Factory setting 210mm Dimensions (H x D x W): 470 x 310 x 227 mm
Weight : 11 kg
Recommended All types of Amplifier Power 15 - 150 W
Origin: FRANCE
Sound Experience Length of Bass Reflex Port - Depending on your room
Ex. 190 mm/ 210mm/230 mm
Speaker Placement - Possible to place against the wall
- Recommended Height of the stand 450 mm
18 600 kr. 15 % rabatt = 15 800 kr.
www.NordicSoundDesign.no
275.2 KB Visninger: 84
275.2 KB Visninger: 81
