TJ skrev:
Er det mulig å klippe ut/lage ovale ovale utklipps-snitt med noen av disse programmene?
GIYF
The Toolbox
You can minimize the Toolbox (send it to the panel), but if you close the Toolbox, you're closing the GIMP.
If you move your mouse over the individual buttons in the Toolbox, a pop-up dialog will appear to identify the tool's purpose.
Click on the button for the tool you want to use in the Toolbox. The button will then be colored in, to indicate that it is the active tool.
Generally, you use a tool on an image by activating the tool, then clicking and dragging on your image. If a portion of the image is selected, then the tool will only work on the selected portion. Selections are identified by a moving dotted-line border (called "marching ants").
Many of the tools have options. Double-clicking on the tool's button will display the Tool Options dialog for that tool.
Tools in the Toolbox
Select elliptical regions
Used to select circular or oval portions of an image. If you click on the image, then press and hold Shift while you're dragging, the ellipse will be a circle. If you click on the image, then press and hold Ctrl while you're dragging, your starting point will be the center of the ellipse (normally, your starting point is at an edge of the ellipse).
Så er det vel bare å bruke cut eller crop.
