Brooklyn is dangerous.
Audiostream ( stereophile) har testet Mytek Brooklyn DAC. Klikk på bildet for å lese testen.
Pris: 18500 Inkludert frakt.
For eiere av Stere-192 DSD DAC tilbyr vi en inbyttedeal på 12000 NOK + frakt
For bestilling: ring 93047149, send mail til info@moiz.no eller PM
Fra produsentens hjemmeside: mytekdigital.com
Brooklyn is a reference USB2 DAC, line and phono analog preamplifier and a reference headphone amplifier.
It integrates digital and vinyl hi-res playback for reference listening on headphones and speakers.​
SPECIFICATIONS :
CONVERSION: up to 384k, 32bit PCM, native DSD
up to DSD256, DXD, 130dB Dynamic Range
MQA HI-RES DECODER: built in certified hardware
MQA (tm) decoder
DIGITAL INPUTS: USB2 Class2 (OSX, Linux driverless,
all formats), AES/EBU (PCM up to 192k, up to DSD64 DOP), 2x S/PDIF (PCM up to 192k, up to DSD64 DOP), Toslink/ADAT 2x S/PDIF (PCM up to 192k, up to DSD64 DOP), SDIF3 DSD up to DSD256
CLOCK: “Mytek Femtoclock Generator (tm)” 0.82ps internal jitter, Wordclock Input and Output (allows stacking multiple units for multichannel operation,
includes mch DSD)
ANALOG OUTPUTS: RCA, balanced XLR, simultaneous,
50 Ohm impedance
HEADPHONE OUTPUTS: Reference High Current,
High transient Headphone Amp, 500mA, 6 Watts,
dual headphone jacks, designed to drive hard to
drive headphones.
BUILT-IN ATTENUATOR: Choice of 1dB step analog attenuator, separate for main out and head- phones,
1dB step digital 32 bit attenuator and purist relay bypass.
BUILT-IN ANALOG PREAMP: Line level input or
Phono M/M, M/C input, relay controlled.
AUDIO INTERFACE FUNCTION: All digital inputs can
be routed into computer via USB2. Allows connection
of external digital sources such as CD Players and
digitizing ADCs.
REMOTE: Included, universal remote capable
FIRMWARE: Upgradable via USB Control panel
WORLDWIDE POWER SUPPLY
OPTIONAL DC/BATTERY POWER INPUT: 12VDC
DIMENSIONS: WxDxH=8.5x8.5x1.74”=216x216x44mm
WEIGHT: 4lbs, 2kg
WARRANTY: 2 years
Moiz Audio
"Digital High-End på øverste nivå" ifølge tyske Hi-Fi Einsull...klikk på lenken for å se omtalen. ( Bruk gjerne Google oversetter for å få med deg essensen)
Moiz Audio
Det er fullt mulig å låne en Brooklyn DAC..ingen depositum avkrevd! Ta kontakt hvis du er interessert!
Moiz Audio
Det er fullt mulig å låne en Brooklyn DAC..ingen depositum avkrevd! Ta kontakt hvis du er interessert! Seriøs DAC,produsert i Europa, populær og lav tapsverdi
Moiz Audio
Moiz Audio sine annonser
The Headphoneer: MYTEK LIBERTY THX AAA HPA Headphone Amplifier Review
På lager igjen! Nøytral, presis og gjennomsiktig lyd uten å irritere ørene. les omtalen her: https://www.headphoneer.com/the-big-mytek-liberty-thx-aaa-hpa-headphone-amplifier-review/ Kjøpslenke...
MOONDROP COSMO Nanoscale Ultra-thin Planar Flagship Headphone
  • 19
Referanse modellen COSMO åpner døren til en verden av eksepsjonell lydkvalitet og avansert teknologi. Disse planarmagnetiske-hodetelefonene tilbyr lyd uten kompromiss. Moondrop COSMO byr på...
The-ear.net omtale av Burson Audio Soloist Voyager
  • 5
Klikk på bildet for å lese den nyeste omtalen av Hodetelefonforsterkeren (/preamp) fra Burson Audio Dette er en en Klasse-A, symmetrisk Dual Mono design og Fullbalansert . En strømsterk...
Trafomatic Audio Primavera Headphone Amp
Flott omtale fra 6moons.com https://6moons.com/audioreview_articles/trafomatic-audio-primavera/ 4 ukers leveringstid. Startpris 12K euro ( avhenger av konfigurasjon) Produktinfo...
MoonDrop Para Hodetelefoner
  • 18
Vi tilbyr nå disse populære hodetelefonene i Norge! Vi anbefaler Moondrop PARA hodetelefoner for audiofile som ønsker en allsidig planarmagnetisk hodetelefon til en konkurransedyktig pris...
SoTM Musikkstreamere Software oppgradering: Eunhasu Versjon 0.5.6
  • 2
SoTM musikkstreamere kan nå oppgraderes til nyeste og beste versjonen av Eunhasu programvaren. Softwaren er installert på SD kort, og selve prosedyren tar 10-15 sekunder, som videoen ovenfor...
