`BRYSTON BDP-2.. få bedre analogfølelse av digitale filer- OPPLEVES hos LYRIC HIFI
The Bryston BDP-2 is a dedicated player for high resolution digital audio files. Employing a modified Linux OS optimized to provide the highest quality audio performance, the BDP-2 will play high resolution audio files (up to 192k/24b) from digital storage devices without compromise. The BDP-2 features an improved power supply, custom Intel Atom powered motherboard, additional input options, and eight times more system memory than the BDP-1.
Now included is a new proprietary Integrated Audio Device card created in-house which provides improved performance, integrated output and sound processing, and is powered directly by a high quality linear power supply.
Inputs: 6x USB 2.0, 1x eSATA, 2x Gigabit Ethernet (RJ-45)
Outputs: SPDIF (BNC), AES/EBU (XLR)*, USB**
Control: 2x RS-232 (DB9)
Audio Formats: AIFF, FLAC, WAV, MP3, M4A, OGG
Features:
  • Dedicated high resolution digital audio player
  • Playback from USB flash drives, as well as USB and eSATA hard disk drives (HDD)
  • Custom Intel Atom Powered Motherboard
  • Eight times more system memory then the BDP-1.
  • Improved power supply delivering over 5 amps.
  • Multiple control options (iPhone, iPod Touch, iPad, Android OS, and PC)
  • User upgradable firmware
  • NAS Connectivity supported
  • UPnP/DNLA Server supported
  • Requires external DAC (see External DAC in Digital Audio)***
Features Continued:
  • RS-232 serial data port for remote control via Crestron, AMX or similar control systems
Options:
* Via the integrated ice1724 Chipset
** Via built in software decoders. USB output requires S1.70 firmware or greater and a DAC that supports standard class 2 USB audio drivers.
*** External DAC required for full 192K/24b performance, but the BDP-1 is also compatible (up to 96K) with the optional DAC modules in BP26, BP6, BP16 and BP17 Preamps, or B60R, B100 and B135 Integrated Amplifiers.
Pris for BDP-2 inkl 25% MVA : NOK 33 680
Lyric HiFi , Torggata 28 , 0183 Oslo
Tlf 22411984 mellom kl 12.00-17.00
Velkommen
Tor Aamodt Haug
oen
Portugal
Har dere ikke ansatte som kan oversette til Norsk?
LYRIC HIFI
Hei Oen,
Jeg tar det for gitt at alle som er på dette nivået mht utstyr har de engelskkunnskaper som trengs.
Trenger du norsk oversettelse, gå inn på siden til Bryston og la Google oversettelses-program gjære jobben og vips har du norsk.
Ha en fortsatt god kveld.
mvh Tor
sigma 6
Hei Oen,
mvh Tor
Det var da et arrogant svar!
E.I.A.
Hei Oen,
mvh Tor
Han fikk svar på det han spurte om:)
Google translatør er et glimrende redskap for de som ikke kan engelsk.
Kanutus
Nesodden
Hei Oen,
mvh Tor
Hvis du leser svaret én gang til, med god vilje, så er det vel ingenting der som faktisk er arrogant? Muligens er det snev av irritasjon der, da det strengt tatt er et litt småfrekt spørsmål å stille (etter min mening) ...
barathsec
Der hvor gjøken alene galer i full Stereo
Noen blir aldri helt fornøyde, regner med at om denne hadde vært av interesse så ville vel google sin oversetter allerede ha blitt brukt, hvis ikke så kan den bli brukt nå..! :cool: hvis ikke så er det bare å lete videre etter andre ting å sette "fingeren" på..!
yngvejos
Hei Oen,
mvh Tor
Her strekker vi oss langt for potensielle kunder.
Hvis du ikke berhersker engelsk (teknisk sådan), er du for dum til å kjøpe dette produktet.
S. Lieng
Hei Oen,
mvh Tor
Det blir vel en prioritering av tid. De som vurderer å bruke over 30 lapper på en dac vil vel ta en tur innom butikken, eller i det minste en tlf for å få mer info om produktet.
chris33
Østlandet
Spennende produkt! Hva ligger forresten BP26 og 4bsst2 på? Forøvrig greit med engelsk. Verre med Setswana og andre språk du ikke finner på Google translate..
monitor
Mysen
We wonen in Noorwegen en dan is het natuurlijk zo dat luiheid geen excuus is voor het ontgaan van produktinformatie op zijn noors.
De verkoper is een grote lul als hij niet tegen dit soort kritiek op een fatsoenlijke manier reageert.
DUS: In NOORWEGEN spreken we noors, en dan zijn het alleen klootzakken als mij die dan iets in een andere taal voorschotelen...
oes
Det er krevende å være spesialistleverandør i denne bransjen. Ofte enkeltpersoner eller små foretak som gjør sitt beste i en tid med internetthandel og redusert kundegrunnlag. Vis gjerne respekt for at disse må prioritere tiden sin. Hvilken service er du forresten mest villig til å betale for? - personlig service og mulighet for å lytte og sammenligne produkter i en hyggelig atmosfære, eller oversettelse av et høyt antall produktinformasjonsskriv inkludert kvalitetssikring? - noen få er kanskje villig til å betale for begge deler, men de fleste kundene foretrekker å kun betale for det første. Mistenker på toppen av det hele at de mest kritiske til engelsken ikke nødvendigvis legger igjen mest penger hos slike forhandlere. Norge er et lite land med betydelig innslag av handel med utlandet og gode engelskkunnskaper. Legg til at vi snakker om nisjeprodukter og entusiastforhandlere, så forstår dere hvor jeg vil hen.
LYRIC HIFI
LYRIC HIFI sine annonser
SOLIDSTEEL eksklusiv import og salg tilbake hos LYRIC HIFI , Torggata 28 Oslo
  • 1
Since their introduction in 1991, Solidsteel audio tables have established a new level of technical and aesthetic refinement for audio and video component support and isolation...
Nye STAX SRS-5100 = SR-L500 elektrostat hodetelefon & SRM-353X driver ankommet
  • 5
STAX SR-L500 elektrostat hodetelefonen og SRM-353X transistor driver/forsterkeren bringer musikk til ørene med detaljer og kvalitet som er fantastisk med stor opplever en fyldig og dyp...
Helt ny modell ProAc DB-1 ankommet. Kom, lytt og glem hverdagen ! LYRIC HIFI
  • 15
Stewart Tyler's magi igjen på sitt beste. Ord blir overflødig, må oppleves ! Herlighetene kan erverves for kr 24 950 pr par for Standard finish og kr 27 560 pr par for Premium finish. For...
WhestAudio THREE Signature riaa - NY ALVORLIG "TRUSSEL" hos LYRIC HIFI Torggt 28
  • 4
WhestAudio THREE Signature riaa - NY ALVORLIG "TRUSSEL" hos LYRIC HIFI Torggt 28 For MC pick-up’er med høy oppløsning Som alle Whest Audio' s design har whestTHREE Signatureblitt laget for...
Vi inviterer til demokveld med FOCAL La SCALA mk 1 tirsdag 2. fra 16.00-20.00
  • 2
Seansen vil foregå i våre lokaler i Malmskriverveien 11 eller Torggata 28 Vi informerer nærmere om hvor dette vil skje avhengig av hvor mange melder ifra at de vil komme. Mail påmelding om du vil...
Vi inviterer også til demokveld med ProAc D-48R torsdag 28. januar fra 16.00-20.00
  • 8
Seansen vil foregå i våre lokaler i Torggata 28 med enkel servering og den største musikalske opplevelse ! ProAc har i alle år fått kun glimrende skussmål av musikkglade brukere som ikke så...
