CEC Cd5 USB Sound system. Et digitalt senter!
CEC sin Cd5 har høstet mange lovorddet siste året, og vi er enige.
Denne erstatter løse DAC'er og gir deg mulighet for å koble til 3 ekstra digitale kilder - f.eks 1 PC, 1 Apple TV og en Sonos.
I tillegg får du et av bransjens beste cd drivverk med på kjøpet.
KOMMER NÅ I SORT ELLER SØLV UTFØRELSE.
Pris: 33.000,-
"In a nutshell
Yes, the HiFi world needs new products like the CEC CD5! The Musical playback ability on display offers a sensational relationship to price. There has seldom been higher quality compact disc playback in this price class! Complemented by corresponding connection options in keeping with the zeitgeist, the belt driven, analogue principle CD player will, in future, provide many hours of extraordinary listening pleasure"
- Alexander Aschenbrunner
Review Hifi Stars | audio magazine 2015
“an extremely successful, really well prepared CD player with analogue sound flair and with the highest level of powerful converter section, which can do justice to all current and foreseeable digital challenges. A really fine piece of equipment for any situation.“
- Holger Barske
Review HIFI einsnull | audio magazine 2015
Since CEC introduced world’s first Belt-Drive CD Transport in 1991, a lot of music lovers have enjoyed its rich musical sound, which CEC continues to improve on.
A heavier stabilizer brings a more stable rotation of the disc and the Belt-Drive system eliminates the affects of vibration and electromagnetic noise caused by the motor rotation.
Digital output and headphone terminal have been added for the first time to a Belt-Drive CD Player. This maximizes the most advanced DAC technology developed by ESS, and the headphone output enables direct listening without amplifier and loudspeaker system.
With USB input connected to PC up to 32bit/384kHz PCM and DSD128/5.6MHz high-resolution music sources can be reproduced through the CD 5. Here the CD 5 works as the high-resolution music reproduction device in addition to an independent D/A converter for CD music.
BELT DRIVE CD MECHANISM:
In order to read the signal recorded with Constant Linea Velocity (CLV) on CD, rotation speed should be slowed down as it goes to the outside.
Usually the spindle motor controls the variation of speed. All CD players and transports place the spindle motor beneath the turntable for CD and the motor shaft works as the turntable center, this is called direct-drive system.
Stable and accurate rotation requires a bigger torque of motor itself, which inevitably creates certain vibration and the electromagnetic noise. In CDC CD5’ Belt Drive the spindle motor is placed independently from the center shaft and vibration as well as electromagnetic noise effect to the CD are thus minimized.
A heavy CD stabilizer provides bigger inertia of turntable and achieves a stable and smooth rotation of discs. Smaller torque motor and longer distance from the motor to the center shaft (turntable) create the ideal fundamentals of music reproduction. By placing the turntable shaft in the center of the top loading open space the rubber belt replacement is now done with ease on the CD5.
ESS DAC CHIP:
The conversion from digital to analog signal is performed by the ESS Hyper stream DAC chip ES9018K2M which is compatible up to 32-bit/384kHz signals. In addition signals through ES9018K2M go through original full-balanced circuit to achieve dynamic and musical reproduction of music.
CEC CD 5 offers two different digital filters, “FLAT”, a standard filer with super linear frequency response to 20kHz, and “PULSE”, a ringing-free pulse-optimized filer with a softer roll-off below 20kHz. You may select easily by the remote control.
DIGITAL INPUTS:
SPDIF input is compatible up to 24bit/192kHz by COAXIAL and TOSLINK terminals. USB input for the connection to PC is compatible up to PCM 32bit/384kHz and DoP reproduction at DSD128/5.6MHz.
ANALOG OUTPUTS:
Both connections are available. Conventional type RCA output, and XLR output terminal for balance connection.
DIGITAL OUTPUTS:
Two outputs are available: COAX and TOSLINK.
LARGE DISPLAY:
A large VFD monitor indicates input status, condition of digital filter, and the input sampling frequency. Independent FL display shows the condition of the performance of CDs.
Three steps may dim the brightness of display.
Tom Egil
tom@endpoint-audio.com
47832922
Endpoint Audio
Endpoint Audio sine annonser
Canor Virtus A3 - 8 utmerkelser på 1 år.
Canor Virtus A3 har mottatt en rekke utmerkelser og positive omtale, og jeg er enig. Dette er en suveren forsterker som gir ekstremt mye for pengene, og samtidig samler alt i en boks. Fire...
Canor Virtus I4S & Verto D4S
Canor Foundation: Når slovakisk rørtradisjon møter moderne transistorlyd *Verto D4S og Virtus I4S – to nye komponenter som markerer en ny epoke for Canor* En ny retning for et tradisjonsrikt...
Thales Elegance – Årets produkt i LP Magazine
  • 1
Thales Elegance – Årets produkt i LP Magazine. Micha Huber som eier HiFiction hvor man produserer Thales og EMT, er hele tiden fokusert på nyvinninger og hvordan man kan få max ut av analog...
Godt Nytt År!
Godt Nytt År!
2025 – Et fantastisk år for analog lyd hos Endpoint Audio 2025 ble et virkelig eksepsjonelt år for Endpoint Audio. Jeg opplevde et rekordår i salg av analogt utstyr – platespillere, pickuper...
Black Friday tilbud hos Endpoint.
Vi kjører Black Friday tilbud, og ønsker å fremheve spesielt varer fra Canor! -15 % på Performance og Premium Line, samt hele 20 % på Reference Line. Tilbudet gjelder fra i dag og frem til 14...
Canor A3 integrert alt-i-ett forsterker imponerer!
  • 1
Canor har siden lanseringen fått en rekke gode tester som samsvarer veldig godt med mine egne opplevelser - fantastisk lyd i en liten pakke for deg som ønsker et enklere oppsett uten en masse...
