CEC DA 0.3.0. Ny DAC fra CEC
CEC var tilstede som vanlig på en rekke rom og hadde igjen messens mest brukte drivverk i form av CD spilleren CD5 som var representert med hele 11 spillere, men også sitt Top of the line drivverk TL 0.3.0 som var på 4 forskjellige rom.
I tillegg Lanserte CEC sin nye DAC som er ment å komplettere TL 0.3.0 med sin superlink mulighet.
Dette er en DAC i det aller øverste segmentet og det vi fikk hørt på virket særdeles lovende. 8 innganger + superlink gjør at dette tar det meste.
Litt info fra produsentens hjemmeside:
CEC DA 0 3.0 - Universal DSP controlled discrete resistor ladder 32bit/384kHz Audio DAC.
The brand new CEC DA 0 3.0 is the original multibit DAC concept with the most sophisticated implementation and highest precision. We based the solution on the best technology available and applied our knowledge and experience taking the design to the extreme.
The CEC DA 0 3.0 - uses a concept called R2R ladder. This is a resistor matrix that is switched for the various output levels outputting a fraction of an internal reference (much like a volume control). In order to bring the performance
of multibit DAC's to new levels the only solution is to build them from discrete components as there are no off the shelf chips good enough. This involves the selection of ultra precision resistors, thermally coupling them and building
a very fast and sophisticated switching logic to control them. The result is an order of magnitude better performance than what is achievable by IC based solution. To take advantage
of the available resolution and bandwidth we had to implement a state of the art digital preprocessing. This is a suite of algorithms that would apply digital filtering and up sampling to the incoming data stream. After processing
a 16bit 44.1kHz CD data stream it is converted to 32bit 352.8kHZ data fed directly to the DAC. This greatly improves low-level resolution and the sense of space. The process is all user controllable and defeatable for purist band non-oversampling use. Apart from taking the uncompromising approach of using discrete ladder technology we have taken exceptional care with the construction and operation of each
circuit within the DAC.
The CEC DA 0 3.0 use transformer or optical decoupling of all inputs, meaning that contaminated ground connection and other interfering signals don't make it to the inside of the unit. The CEC DA 0 3.0 have no output filter at the DAC output providing the cleanest possible output signal, just a transformer matching the impedance of the converter resistors to the outside world and isolating them from
external influence.
The CEC DA 0 3.0 use completely separate power supplies for each block in the DAC: the Converters, Clock, DSP and Control logic all with floating ground planes and our unique constant current regulator technology. Then the whole assembly is mounted in a solid aluminum case for vibration damping and EMI/RFI screening. The CEC DA 0 3.0 is a different league from all currentlyn available high end DAC's.
The feature list includes among others: Multibit conversion, DSD64 and DSD128 support, 1ppm resolution, Transformer isolated output, No I/V conversion or output buffers, no filtering after DA, total galvanic Isolation of internal circuits from outside world, Internal clock generators, Selectable reclocking, Selectable upsampling, Selection of 4 digital filters.
The CEC DA 0 3.0 D/A converter is the ideal counterpart for CEC wholeheartedly recommend CD Transport TL 0 3.0. You get music reproduction quality at its finest. The calm, supreme composure and confidence with which the TL 0 3.0 and DA 0 3.0 produce music together recall the playback by an analogue mass-loaded turntable.
The concentrated application of know-how, innovative capacity and decades of experience have quite obviously paid off.
CEC SUPERLINK Digital Signal Transmission System Connection was redesign for the new DA 0 3.0. SUPERLINK is CEC's proprietary digital signal transmission system that transports music signals and synchronization (clock) signals with separate cables. The SPDIF- and AES/EBU- systems, commonly used in coaxial digital outputs and optical outputs, transmit both the music and clock signals through the same cable, and thus are prone to jitter effects caused by the signals interfering with each other. CEC's SUPERLINK system transmits these signals separately with multiple cables, requiring no encoding/decoding process for data transmission. It minimizes deterioration of the music signal during transmission by using the clock signals from the D/A converter's master clock generator to achieve complete synchronization.
CEC combines the best drive system, an very excellent transfer concept and precise signal processing to create a CD drive/converter package with superior sound quality - to pack more into these products is currently unimaginable.
Link til CEC:
http://www.cec-international.com/PAGES/s25.html
Tom Egil
Virgo
Den CEC beltespilleren var helt fantastisk da jeg hørte den i Munchen nå
Den sto ikke tilbake for de fleste lp rigger jeg hørte. Dessverre er den altfor dyr
oyvindk
Satt og hørte noen sanger på det systemet der, og jeg synes at det låt veldig bra fra alle kildene.
hvalross
Jeg har den rimeligste CEC CD spilleren XR 51 L tror jeg den heter . Har nylig fått prøvd en Tron Seven rørdac som koster kr.80.000 ny. CEC cd spilleren spiller bedre direkte koblet inn i Forforsterkeren . Så dacen i denne CEC spilleren må være meget -meget god. Dette er vel litt merkelig da CEC spilleren kostet ny ca.kr.25.000 for 4-5 år siden. Med den nye dacen til CEC skulle det vel bli enda bedre -eller kanskje ikke . Hva er prisen på denne dacen .
Endpoint Audio
Tønsberg
Denne DAC'en kommer til å koste noe slikt som det dyreste drevet - rundt 250-300K så det er tatt helt ut og opp. De har allerede det som heter DA3N som koster 41.000,- Den nye CD spilleren cd5 til 35000,- har en nyere dacløsning og spiller voldsomt bra, og det vil komme en nedskalert utgave basert på toppmodellen i en mere fornuftig prisklasse.
hvalross
Det som kanskje er mest intressant er hvordan CEC Dacen til kr.250.000 låter kontra CEC s billigere Dacer tilkr.41.000 for.eks. Mye bedre eller bare litt . Jeg fikk egentlig litt sjokk da jeg testet Tron Seven Dac til kr.80.000 kontra min CEC CDspiller til kr.25.000 nypris for 5-6 år siden . CEC spilleren spiller rett og slett bedre.
yngvejos
Jeg ville styrt unna billigere modeller av noe i den prisklassen. De som kjøper toppmodellen vil forvente at de billigere modellene skal være dårligere, men det er vanskelig å lage en dårlig dac, så da må man ha åpenbare konstruksjonsfeil eller dsp på de rimeligere modellene for at det skal være hørbar forskjell.
Final
HIFI bransjen er spesiell. Objektive standarer som alle aksepterer finnes det få av. Et virkelig godt produkt av høy teknisk kvalitet koster penger. Mark Levinson gikk overende selv om det ikke akkurat var billig. Tror man skal være forsiktig med å kategorisere.
Uansett dette er en bransjetråd med nyheter. Den er til for å presentere nyheter. Det er interessant å lese og en grei måte å informere om produkter på.
Synes det er litt synd at trådene nesten alltid utarter.
Har man et rimelig transparent oppsett høres lett store forskjeller på DAC. Da låter en dårlig DAC skikkelig dårlig og en god DAC skikkelig godt. En god DAC med lav jitter og forvrengning som er kvalitetstegn jeg ser etter koster en del.
KrazyIvan#
porsgrunn
ikke at jeg har noen formening om nevnte c.e.c. dac men jeg hadde den rimeligere modellen tl 51 med fjernet analogkort og kjørt som ren transport inn i tilhørende c.e.c. dx 51 mk2 og det er faktisk en av de mest likende komboer jeg har hatt i hus med tanke på musikalitet og et luftig velballansert lydbilde som både var stramt luftig og med ``mellomtonemagi`` synes ihvertfall dem som tviler på c.e.c. sine produkter bør tørre å prøve noe fra dem før dem sier hva som er ``hva`` :) og mye av c.e.c. sine produkter er ihvertfall value for the money hva musikalsk anngår :) og ja har testet mot endel annet som ikke har gitt meg samme mellomtone gleden som c.e.c. besitter noe også endel dyrere :)
X-Cell
Lorden av Nord!
Hold tråden fri for usakligheter og barnsligheter.. dette blir for dumt.
Videre kan dette få være en bransjenyhet også får folk diskutere under en vennetråd eller annen tråd.
X-Cell
Lorden av Nord!
Tråd ryddet enda mer. Det er en bransjenyhet. Diskusjoner om priser, om billig eller dyrt er snakeoil,osv kan tas andre plasser.
Seriøse spørsmål kan stilles.
TT.
The smooth jazz guy! 😉🇳🇴
Nedre Tonsåsen
Moderering/advarsel er rapportert Høvdingen!
Kanutus
Nesodden
Edit: Om moderering; tatt av selvsensuren ...
Endpoint Audio
Endpoint Audio sine annonser
Nyhet fra Degritter - Fonoteek - leveringsklar Januar 25. forhåndsbestillinger fra 1.September
  • 5
Fonoteek Fonoteek is the ultimate vinyl record cleaning station. The device uses brushes and ultrasonic cleaning together with cleaning fluid to remove even the most stubborn dirt from your disc...
Canor Audio hos Endpoint Audio
  • 1
Jeg er veldig fornøyd med å kunne re-introdusere Canor for det norske markedet, og gir i den forbindelse 15% avslag på alle produktene en kort periode nå i begynnelsen av april. Canor Audio har...
Lockwood Loudspeakers hos Endpoint Audio
  • 3
Jeg er meget fornøyd med å introdusere Lockwood for det norske markedet. Etablert i 1930, Lockwood har vært en av de mest foretrukne monitorer med over 1200 plateinnspillinger på ryggen. Så...
Innbyttekampanje! Oppgrader til Lumin U2 - Eller få 15%
Ønsker du å oppgradere til en av markedets beste streamere? Lumin U2 har oppgradert prosessor, dedikert Low Noise USB til DAC utgang, all-in-one chassis, fiber nettverk, OG lineær...
God Jul til alle!
God Jul til alle!
  • 9
Jeg ønsker alle en riktig God Jul, hvor kanskje både harde og myke pakker er det minst viktige. Det skjer såpass mye galskap i verden i dag, at den beste gaven vi kan gi er medmennesklighet...
EMT 912HI - Test.
EMT 912HI - Test.
EMT lanserte i 2022 nye utgaver av de legendariske tonearmene EMT 929 & 997. Disse er vesentlig oppgradert i forhold til forgjengerene og det legger man merke til med en gang man tar de ut av...
