Den store hodetelefontråden
  • Moiz Audio
    mariusaa
    Hvorfor har ingen gjort dette med verdens 50 beste høyttalere, forresten??
    En ting er at noen hodetelefoner er dyre, men høyttalere er overpriset til det latterlige. Priser på over 100.000kr for noen tre kasser med ett par elementer er så dumt at jeg får ikke sagt det på noen pen måte som egner seg i det offentlige rom. Ser liksom ingen bruke noen millioner på å skrive omtale av de 50 "beste".
    ardilla
    OSLO
    Nettopp ;) De 50 "beste" ligger vel alle over millionen. Vanskelig å lagre en slik samling er det vel også. Styr å handle alt.
    Heia hodetelefoner, la oss samle i vei. Tror jeg skal skaffe meg et slikt femtihodetelefonersskap.
    Ellers kan man jo bare kjøre enkelt:
    Tittentei
    Om Sennheiser Orpheus HE90.
    ATROCIOUS DESIGN FLAWS: I remember, after using the HE90 for the first time, I removed the headphones from my head only to find little black particles near my ear and on my fingers. This was the result of the faux-leather used in constructing headband and earpads. I thought that there was something wrong with my pair, but I quickly learned that this was a typical occurrence with the Orpheus. How could Sennheiser design what was intended to be the world's most supreme flagship headphone and not use better materials than this? In some ways it does take away from the joy of owning an Orpheus. Every time one uses it, the quality of the headband deteriorates to some degree. If Sennheiser objects to using real leather for animal rights reasons, I fully respect this, but the materials used here are clearly cheap and inadequate. A third party would be wise to create a real leather replacement for this headphone. I remember that the manufacturer JMoney had proposed the idea of creating a leather headband replacement for the HE90, but I don't recall what came of this proposition.
    EXTREMELY EXPENSIVE:
    To my knowledge, the HE90 and its required amplifier is the most expensive headphone system of all time. Depending on the condition, expect to pay somewhere between 7 and 11 grand for the headphone alone. If the amp and headphone are sold together, the asking price may be more than your car's. It is hard to put a price on something that is perceived by many as the best in the world. While I do perceive the sound quality of the HE90 to be the best in the world, I cannot justify the price and I do not recommend purchasing it. If you intend on purchasing the HE90, make sure you can accept that a well-driven HD800, LCD-3 or HE-6 (all currently in production) can get close to the resolution of the HE90 at an extreme fraction of the price.
    Oppskrytt jallemikk.
    Reaksjoner: KML
    sorgenfri
    Vis vedlegget 163413
    Vis vedlegget 163412
    Han hadde mye fint i skapet han, men det er bra innhold i mitt også...
    Reaksjoner: KML
    Tittentei
    Nei, her finnes ingen selvmotsigelser, det er en logisk feilslutning i resonnementet ditt.
    1) Påstanden er at "Min erfaring er at pris og lyd har høy sammenheng innen hodetelefoner"
    2) Skalaen min viser min subjektive oppfattelse av utbyttet man får fra head-fi generelt RELATIVT TIL stereo, det vil si; hodetelefoner, DAC, hodetelefonforsterker, kabler. Med andre ord alle komponenter som inngår i et head-fi oppsett relativt til et stereooppsett.
    Du kan tolke påstand (1) som at jeg ville vært villig til å legge mange penger i selve hodetelefonen, men samtidig mener at andre dyre komponenter gir mindre utbytte i et head-fi oppsett enn om ressursene ble lagt til et komponent i et stereooppsett.
    3) Den flater ut fortere enn på stereo. Lær å tolke grafer som er relative før du trekker slutninger.
    I den originale grafen din vises det tydelig at du mener pris/ytelse flater veldig fort ut på hodetelefoner.
    Du motsier deg selv!
    Min erfaring er at pris og lyd har høy sammenheng innen hodetelefoner. Det er veldig få dyre hodetelefoner, og de dyre har det som regel blitt lagt veldig mye arbeid i å få så gode som mulig.
    Legger ved bilde av skalaen, og ja, jeg står bak den enda. Her finnes ingen selvmotsigelser.
    Tittentei
    Ardilla, du er helt sjukt hitler på hodetelefoner. Vi kjører moped! Deal with it! :D
    CDWMcInSpots
    Bergensregionen
    Figurtolkning: Har jeg forstått eller misforstått (noe)?
    Halvstrukturert høyttenkning (med litt hastverk):
    Det dukket nettopp opp en ny tanke i mitt hode ang. denne figuren. Kanskje er jeg forvirret, eller kanskje kan figurens utforming og tekst forlede.
    Figuren har to akser, pris og ytelse, men ingen benevninger. Videre har den to grafer, hodetelefoneri og stereo. I første omgang leste jeg den som at et aksepunkt har samme verdi f.eks. kr. 10000 for begge grafer, men nå slo det meg at dette kanskje ikke er slik, eller er det kanskje nettopp det?
    Hvis krysningspunktet f.eks. er nettopp kr. 10000 (eller noe lavere), er hodetelefonerigrafen antagelig rimelig god. ardilla skrev f.eks. tidligere i uken at man kan bruke mye mer penger enn det beyerdynamic T 1 koster, og få en litt/noe bedre hodetelefon.
    Det er derimot neppe stor uenighet om at det skjer en del også over kr. 10000 for høyttalere.
    Dette er jo ingen overraskelse. Mange av oss har jo skrevet at dette nettopp er en av fordelene med hodetelefoner. Hodetelefoner og hodetelefonforsterkere gir bedre lydkvalitet per krone enn høyttalerbaserte oppsett så lenge man ikke har behov for buksebensflagrende bass og ikke har problemer med hodetelefoners lydpresentasjon.
    Hvis jeg har forstått (noe), blir vel dette (lett) galt(?)
    Eksempel (gjelder kjøp i Norge):
    En ny klokke, kikkert, hagle osv. til kr. 100.000 er (forhåpentlig) meget bra, og det kan t.o.m. være vanskelig for produsenten å benytte alle kronene på fornuftige produktegenskaper og kvalitet.
    En ny bil, enn si et vogntog, en dumper eller en stridsvogn til kr. 100.000 er neppe på langt nær like god, og gjerne også en umulighet.
    Forskjellige produkter og produktkategorier har ulike prisskalaer og dermed priser for samme funksjons- og kvalitetsnivå.
    Tittentei
    Du har forstått grafen.
    Figuren trenger ingen benevninger for å illustrere poenget den er ment å illustrere. Før skjæringspunktet får man mer ytelse per krone ved å investere i head-fi, i krysningspunktet er forholdet likt mellom head-fi og stereo og etter krysningspunktet vil ytelse per krone være bedre om lagt i stereo.
    Dette er en subjektiv skala av hvordan jeg opplever verden. F.eks. så jeg hvordan en forsterker til 3 000 kroner fra Asus, fint kunne måle seg med Grace Design m903 til ~15 500 kroner. Likeledes om forskjellene mellom Audeze LCD-2 til 8 000 og LCD-3 til 17 600, selv om LCD-3 i mine ører er best og kanskje også verdt prisdifferansen, så hadde jeg heller brukt pengene på høyttalere om det var en praktisk mulighet og alternativene gjensidig utelukkende.
    Her ble det siktet til det jeg opplever som ardillasutring. Noe som oppstår dersom man prater favør av stereo på bekostning av head-fi. Mannen vil bli reinkarnert som en HD 650, det er jeg sikker om!
    CDWMcInSpots
    Bergensregionen
    Takk.
    For meg var det delen i rødt som var interessant, og det var den jeg så kommenterte.
    Morpheus
    Jeg varierer mellom he-500, d7100 og w1000x etter humøret. He-500 når jeg er ute etter peneste lyden; den har mest luft, tykkeste mellomtone og diskant, samt dypere bass enn w1000x. Men i forhold til d7100 og w1000x så er he-500 direkte ubehagelig å ha på seg pga vekten av de. Men så er D7100 og W1000X ekstremt komfortable. W1000X bruker jeg når jeg vil høre på noe som jeg føler ikke krever noe som helst av meg som lytter. Enkleste måten jeg kan forklare w1000x på er at de er som m50 hvor ALT er forbedret. D7100 er for når jeg vil føle musikken fysisk. Om de er med på top 3 av det jeg har hørt? Hvis jeg ser bort i fra lcd-3, noe jeg har tenkt å gjøre siden de ikke passet meg, så: ja. Men å plassere he-500, d7100 og w1000x på noen plasser klarer jeg ikke, for det avhenger helt av dagsformen hva jeg liker best. Men det er i det minste de 3 som er på topp så langt for min del. Når det gjelder andre audio technica så har jeg hatt m50 (knall til prisen) og a900 (absolutt INGEN bass). Vurderte w5000 og 3000anv modellene, men leste de har begge mindre bass enn w1000x - og noe mindre enn w1000x er for meg uaktuelt. Elsker utseende på ad1000, og nyskjerrig på a1000x og a2000x.
    Takker for informativt svar :).
    Tittentei
    CDW peser Høvdingen om Wiki. Det kunne vært nyttig.
    Andre steder oppretter de "Forsterker til hodetelefon xyz". Som regel velger folk hodetelefon før forsterker, så forekomsten av "Hodetelefoner til forsterker abc" er sjeldnere skue.
    Problemet med slike tråder er at de ofte sklir ut. Anmeldelser trenger heller ikke være lange og omfattende. Liker formen til mariusaa og punktlistene til Lovhagen. Lyden i hodetelefoner kan beskrives over få linjer.
    HD 650 + Asus Xonar Essence One = Mørk lydsignatur, bra kontroll og hardere og raskere dynamikk enn om drevet med slappere utstyr. Litt mindre flytende og myk enn med WA6-SE fra Woo Audio eller Grace Design m903 (litt skarpere i toppen med HD 650, men slappere i bunn), men fortsatt en HD 650 med varm mellomtone og fløyelsmyk diskant som ikke blir skrikete på dårlige innspillinger.
    ardilla
    OSLO
    Man kan vel anta at Fang lærer. Men det vet han jo best selv. Trolig blir det for dyrt..
    Lateralus
    Duet Audio er norsk importør av Fosgate / Musical Surroundings, Audio Norge er forhandler. Vi håper å få inn denne i løpet av november.
    Sture
    Audio Norge
    Loevhagen
    L -> her <- H
    He, he. Det er litt morsomt at jeg nå er på nippet til å bestille at par HD800 med balanserte kabler. Jeg er litt spent på om gjensynet er gledelig eller ikke når det kommer til HD800.
    HiFiMAN HE-6 har fått en ny vår her hjemme, så kanskje HD800 også inngår i den årstiden...
    Farsdag, et al.
    ardilla
    OSLO
    Det er fremdeles mange hodetelefoner du ikke har....
    Farsdag, et al.
    Tittentei
    Skulle gjerne tredd hodet inn i den kontrapsjonen fra Sony der. Bass heavy MDR-R10 hadde også vært gøy. Den dagen man er ferdig med utdannelsen og satt i heltidsarbeid altså! :D
    ardilla
    OSLO
    ....har du ikke tid til å samle ørevarmere ;)
    Loevhagen
    L -> her <- H
    R10 (bass light eller heavy) frister ikke. Orpheus ditto. K1K følger samme vei. Taket også (ennå - men om 2 års tid; hvem vet). Man går nok "glipp" av noe, men så lenge man har hvilepuls og gir fxxx så får andre stresse seg opp med alle såkalte klassikere. Hadde jeg vært fjortis, så ville nok pulsen vært høyere - liksom - seriøst - elns.
    mteinum
    Øya
    K-1000 kunne godt funnet veien hjem her.
    Lateralus
    Duet Audio er norsk importør, Audio Norge er forhandler. Vi håper å få inn denne i løpet av november.
    Sture
    Audio Norge
    På direkte spm, kan du skrive litt om pris, innganger etc?
    Christian.
    Prisen på Fosgate Signature Tube Headphone Amplifier har blitt satt til kr. 9.990. Skal gi mer info om selve produktet senere.
    Sture
    Audio Norge
    sorgenfri
    Sture
    Audio Norge
    Christian.
    Sture
    Audio Norge
    Sorgenfri takker​ for innlegget
    Tittentei
    LOL, ja, mye av populariteten og hypen kan nok tilskrives psykologien i det å ønske seg det utilgjengelige. :) Det ser vi blant samlere generelt. Likevel er det klart det hadde vært festlig å prøve. Om man klarer å legge fra seg Gollumentusiasmen forut for testing, så hadde det vært gøy å se om de virkelig er så gode som alle skal ha det til. Nå har vel noen av titanene innen head-fi uttalt at SR-009 overgår Orpheus, og da til en brøkdel av prisen så... :)
