Digital RIAA-korreksjon
P
Parelius
Så denne omtalen på nett:
Transfer engineers who use digital processing (such as CEDAR) for removing noise on 78-rpm recordings sometimes find that a flat initial playback allows the digital noise removal to work better, before the recording curve is applied. The flat position can be extremely useful here. The disc is played without equalization, then fed to the digital processor. The EQS MK12 also has a line input, just ahead of the equalization circuitry, which allows you to apply the recording curve at line level, after the digital pro- cessing has been done. Some engineers will tell you that you can apply the play- back curve in the digital domain, and the equalization capabilities of many computer-based digital processors and editors will allow you to do this.
There's a flaw in this approach, however. Among the virtues of digital equalization is the lack of nasty phase shifts inherent in analog filters. In the case of playback curves, the lack of frequency-dependent phase shifts presents a problem. Most readers know that the playback curves provide proper frequency equalization for the record. What is generally ignored-probably because it happens automatically-is the fact that the play- back curves also provide correct phase equalization. The filters used to pro- duce the recording curves in the first place caused phase shifts. When complementary analog play- back equalization takes place, the phase response of the record is also corrected. Ideally, a properly equalized record will have flat frequency and phase response (the fact that we can geta credible square wave off an LP test record is proof that we can come pretty close when everything is working properly). To achieve this, old-fashioned analog playback equalization is the only way to go; digital filtering won't accomplish this task.
It should certainly be possible to design digital filters to mimic both the phase and frequency characteristics of analog filters, but no one has yet done this commercially for playback equalization of disc records, as far as I know.
Kilde.
Stemmer dette?
Edit: Lagt inn korrekt lenke.
Bx
Stemmer hva?
Dette kan gjøres digitalt. Den frekvens-/fasegangen som eksisterer i analoge implementeringer kan også gjenskapes i et digitalt filter.
Det er en del diskusjoner av RIAA-korreksjon på nettet, der man blant annet drøfter avviket mellom den teoretiske RIAA og slik den er implementert i praksis (med et lavpassfilter rundt 50 kHz). Impedanstilpasning til pickup er jo også et tema om jeg har forstått dette riktig. Så det vil fortsatt være noen analoge utfordringer her.
Men det å implementere selve RIAA korreksjon digitalt er en smal sak bare man har en presis beskrivelse av det man skal implementere eller - enda bedre - av det man skal invertere.
Om det eksisterer kommersielle løsninger p.t. vet jeg ikke. Jeg ser ikke bort fra at det dukker opp i Audiolense i overskuelig framtid.
slarssen
Synes jeg leste en artikkel for en god stund siden, der noen hadde laget e lite kort med en xx-bits ADC som var montert på oversiden av platespiller armen, helt ytterst med PU'en. Den samplet da utgangen fra PU'en direkte og overførte signalene digitalt til en digital prosessor. Husker ikke hva den het eller hvem som lagde den... desverre... tror det var i et Audio blad, eller kanskje Lyd og Bilde? Lenge siden i alle fall...
Har ikke hørt noe om det siden, så det er mulig de som gjorde research på dette fant ut at det ikke var noe særlig... :)
- Stig
K
knutinh
Hvis du har et "godt" analogt invers-filter så kan du jo bruke verktøy for måling av impulsrespons til å modellere filteret digitalt med den presisjonen du måtte ønske.
Så var det dette med hørbarheten av lavereordens fasedistorsjon. Hvilken filter-orden er det i et RIAA-filter?
-k
-k
1. ordens filter, definert med tidskonstanter: 3180 µS HP, 318 µS LP, 75 µS LP. Av og til benyttes også en HF korreksjon iht. garantibestemmelsene for Neumann sine skjærehoder ved 31,8 µS HP, og IEC subsonisk filter ved 7960 µS HP.
K
knutinh
KJ skrev:
-k
Da er jeg fristet til å avskrive lineær fase vs ulineær fase som et ikke-issue for RIAA-korreksjon.
-k
